Blackbird Rush
posted on 28/9/08 at 08:41 PM |
Megasquirt Serial Link Testing
HI,
Just assembling my MS1 V3 and i have got to section 26, serial link test, i've got a USB to DB9 cable and have succesfully set this up and
tested it with both mini term and hyperterm with jumpers across pins 2&3.
When plugged into the V3 board (stim & 9V battery connected) with pins 12 & 13 jumped the loop back dosn't work.
Any obvious things to check?, the boards only got a few capacitors and diodes on it and the soldering looks OK.
Cheers for any pointers
Ash
novacaine
posted on 29/9/08 at 10:17 AM |
check that you have a female DB9 soldered to the board, that was my mistake
And you run and you run to catch up with the sun but its sinking, Racing around to come up behind you again, the sun is the same in a relative way but
your older, shorter of breath and one day closer to death
Blackbird Rush
posted on 29/9/08 at 11:24 AM |
Yep, have a female DB9....
