omega0684
posted on 20/2/09 at 04:06 PM |
high impedence injectors and MS
i have high impedence injectors on my ITB's, the ms manual says
To tune the PWM [pulse width modulation] values for your engine, you need to know what kind of injectors you have: low impedance or high impedance.To
If you are running high-impedance injectors (greater than 10 Ohms), then set the:
PWM Time Threshold to 25.4 msec, and the
PWM Current Limit (%) to 100%.
In essence you are disabling the PWM mode. This allows full voltage to the injectors throughout the pulse widths.
so does this mean i dont have to set the pulse width criteria because there is always 12v's on the injectors and they won't burn out cuz
they are high impedence.
vinny1275
posted on 20/2/09 at 04:19 PM |
Yeh, there's something different you have to do with the low-impedence ones, but if you have high-impedence you can just bung in the settings
from the manual and forget about it....
Vince
mark chandler
posted on 20/2/09 at 04:40 PM |
If you use car injectors these will tend to be 10ohm each, bikes are around 50ohm.
The output transistors on the MS standard board can run a pair of bike injectors without boiling up so a 25ohm load as parallel wired.
A pair of car injectors would be a 5ohm load which causes problems, MS deals with this by giving pulsing the current to the injector, so a long pulse
to open it then lots of little pulse to hold it open, this effectively halves or quarters the load on the transistors, pretty clever really.
regards Mark
