posted on 20/11/09 at 03:15 PM |
Ford Fuel Rail??
Excuse me peeps, I have strange diaphragm type thingy on my fuel rail, it doesnt restrict fuel or protrude into the rail but I would like to know what
its is....
I was thinking of flattening the end and soldering it up as I do not want fuel squirting out of the little bugger.
Ta,
stuart_g
| posted on 20/11/09 at 03:17 PM |
Is it the fuel pressure regulator?
tomgregory2000
| posted on 20/11/09 at 03:21 PM |
looks to me as the fuel pressure regulator
you want fuel to come out of that
| posted on 20/11/09 at 03:22 PM |
Don't think so as its in the middle of the rail and the outlet there is quite small.
Focus it came off has intelligent variable fuel pump that doesn't need a regulator.. end of the rail had a sensor on it, now with barbed
outlet
| posted on 20/11/09 at 03:29 PM |
Looks like it is a pulse damper, the outlet is really a only vacuum connection.
A lot of recent tintops now have the pressure regulator in tank and the main control of the fuel pressure is electronic control of the fuel pump
speed.
Werner Van Loock
| posted on 20/11/09 at 06:59 PM |
Can't it be replaced by a fuel pressure regulator? No need to plumb a seperate one in then.
| posted on 20/11/09 at 07:06 PM |
Thanks, fettled it now, 20 seconds with the mig...
I'd already put a return on the end of the rail and sorted the regulator forgetting about, so, now its redundant and no longer a worry.
stuart_g
| posted on 21/11/09 at 12:15 AM |
Why aren't you using the throttle body injectors and fuel rail? Just curious.
| posted on 21/11/09 at 01:23 AM |
Front rail is the original ST170 injectors, I spent ages getting them to the same position.. TB injectors may be used for top end wooooooooooosh...
scutter
| posted on 21/11/09 at 11:16 AM |
Sorry to jump in, but a 2.0L mondeo rail fits nicely and comes with a pressure regulator.
ATB Dan.
