cd.thomson
posted on 28/11/09 at 02:35 PM |
2-core overall lapped screen Q?
has anyone bought and used this cabling with their VR sensor? I just bought 3m but each core is TINY, 7 copper strands in each. Will this be okay?
http://www.maplin.co.uk/module.aspx?moduleno=127
Craig
r1_pete
posted on 28/11/09 at 03:34 PM |
I used microphone cable, its about 6mm overall diameter and a bit more robust for under the hood....
This Stuff
Lars
posted on 28/11/09 at 05:52 PM |
i used that microphone stuff as well
Chippy
posted on 28/11/09 at 11:05 PM |
Hi, I used the same cable that you have purchased, had no problems to date, now over 7K miles. Didnt like the look of the mic cable as it looked to be
solid core, so stayed with the multi strand stuff. I think the amount of current that is used in the VR sensor is negligable. Cheers Ray
brianthemagical
posted on 29/11/09 at 11:16 AM |
The stuff yo've bought will be fine. As above, the current will be very very low. The voltages are also low so make sure the connections are as
sound as possible.
posted on 29/11/09 at 12:54 PM |
solid core,
If it's microphone cable it won't be solid core. This kind of cable needs to be extra flexible since it gets moved a lot.
However neither microphone cable nor the stuff the OP has bought is rated for automotive use (e.g. abrasion resistance, temperature range and oil
resistance) so make sure you route it well away from the exhaust.
posted on 29/11/09 at 02:13 PM |
I bought mine from triggerwheels - it's quite substantial, and the outer cover is rated for oil, heat, petrol, etc.
Maplins may be cheaper, but the proper stuff didn't exactly break the bank.
