doddy
| posted on 27/3/10 at 02:51 PM |
help with megasquirt on zetec cant connect to laptop
hi need some help
im having a bit of trouble with connecting my megasquirt v2.2 to my zetec engine
so far im using edis and i have sparks fine its turning over fuel pump working fine
but will not start i had it fire once but not start
when i connect to laptop it comes with controller code verson warning expected ms1/extra format 029y3 recieved 024s
so i down loaded another verson ms i used original bg code version that bought up expected "ox14 recieved "" but this connents to
the laptop and i can see things work like tps and temp but it still does not start
can any one help the ms was ment to have extra code loaded but i did buy it of ebay so cant be 100% sure
this is the ad
<eBay links not allowed on these forums>
cheers doddy
FrankP
| posted on 27/3/10 at 02:59 PM |
Hi - are you using tunerstudio?
What is the injection set up
Yiou will need to setup your startup enrichment and idle valse settings...
Frank
doddy
| posted on 27/3/10 at 03:35 PM |
cant get my laptop on line so cant downlod it
which is most of the problem i might go buy a new one
i have black top zetec with gsxr 600 tbs with gsxr injectors
i think i need to find the software to run format 024s
matt_gsxr
| posted on 27/3/10 at 03:52 PM |
You could download to a USB stick and then copy it onto your laptop with that. A small USB stick don't cost much (if you haven't already
got one).
If you do decide to get a new laptop, then either you need it to have a serial port, or you need a USB to serial adapter.
doddy
| posted on 27/3/10 at 05:34 PM |
ok i now have sorted the laptop
i now have tuner studioms
when i start a new file it looks for the firmware for 024s but cant find it
how do i load a new code
[Edited on 27/3/10 by doddy]
atspeed racing
| posted on 10/4/10 at 03:11 PM |
are you using a usb adapter? or serial cable?
most problems with ecu -> laptop connectivity occur with usb adapters and the change in bus speeds.
most tuners will pretty much always have a laptop with RS232 serial cable input.
- colin.
