clairetoo
posted on 15/5/10 at 11:51 AM |
LC1 programming problem
I'm just in the middle of sorting out a new LC1 instalation - and I cant get my head around programming it
I have done the free-air callibration , and as far as I can see set it to 0 to 5 volts , but the gauge dosnt read right - it sits at a reading of 8 ,
without moving when the throttle is touched .
Any ideas what I'm doing wrong ?
Its cuz I is blond , innit
Claire xx
Will weld for food......
hobbsy
| posted on 15/5/10 at 02:14 PM |
Free air calibration is all I did on mine then it worked fine.
I know I'm stating the blooming obvious here but you do have to do that bit with the sensor out of the exhaust! I guess if you don't it
could put it quite out of whack.
What are you using as the gauge? One of Innovates like an XD-16 or something else?
Dave Bailey
| posted on 7/8/10 at 03:37 PM |
Sorry to hijack this thread but what lambda value did you get when you did your free air calibration? I seem to have AFR of about 22
I have an LC1 with a wideband sensor and I think the voltage range is 0 - 7V so I have a voltage of above 5 Volts which in the lookup table in my DTA
ecu is in excess of Lambda 1.5...
Dave B
interestedparty
| posted on 7/8/10 at 04:28 PM |
Surely the 5v is the reference voltage its supposed to get from the controller?
coyoteboy
| posted on 11/8/10 at 12:09 AM |
Are you following the instructions? It's 3 years since I did it but IIRC it was as straight forward as following the text. Don't forget
they have two outputs too, make sure you pick the right one.
dlatch
| posted on 11/8/10 at 12:51 AM |
also the LC-1 has two outputs
first is for a bog standard afr guage (simulated narrow band signal) second is to the ecu or to a proper wideband afr guage and will give the 0-5v
range
for this to show correctly in something like megatune i had to start a new project and telling it that the LC-1 was fitted until it displayed the
readings correctly,
