Author: Subject: Tuner studio settings
adrianreeve
posted on 18/3/11 at 09:16 PM Reply With Quote
How do I specify that i have a 36-1 zetec flywheel in TunerStudio? Can't find the right setting anywhere! Also, is it worth spending the extra to get the upgraded version?
Adrian
ashg
posted on 18/3/11 at 11:08 PM Reply With Quote
click on ignition settings then ignition options/wheel decoder
u have the upgraded version. the big things you get with it are ve analyse live and it shows you exactly what is different between your ofline map and the one on the ecu.
[Edited on 18/3/2011 by ashg]
Haynes Roadster (Finished)
Exocet (Finished & Sold)
New Project (Started)
ashg
posted on 18/3/11 at 11:12 PM Reply With Quote
do you have a base map for your zetec? if you get stuck let me know and i will pop over one evening and get it running for you.
adrianreeve
posted on 18/3/11 at 11:21 PM Reply With Quote
You're a star Ash!
Still waiting for an exhaust, so may be a while, but I may well take you up on the offer. Hows the new car coming on? And the engine swap? You're making me look bad, I started before you!
Be good to catch up soon.
Adrian
ashg
posted on 19/3/11 at 12:42 AM Reply With Quote
Engine swap is pretty much done, just need to tidy a few bits up, but it is drivable the new exocet I'm building will be done before you finish if you are not careful
