Nitrogeno25
| posted on 2/8/12 at 01:09 PM |
Megasquirt and EDIS - Shielded wire
I'm wiring the EDIS module to the megasquirt and trying to decide how to wire the PIP and SAW.
I have the option of use some shielded microphone wire or twist a pair of wires (suitable for car use) and then shield them using the mesh from a
coaxial cable and maybe wrap in aluminium foil.
Which one is best?
Thank you very much!
big-vee-twin
| posted on 2/8/12 at 01:22 PM |
I've used Microphone wire the cores are twisted and a tin foil sheilding is also built in
http://www.triangleltd.com
| posted on 2/8/12 at 04:58 PM |
PIP and SAW wires don't need shielding, only the sensor wiring.
scudderfish
| posted on 2/8/12 at 05:08 PM |
According to this http://www.extraefi.co.uk/Drawings/PDF_Files/Edis_Wiring.pdf the PIP should be shielded.
| posted on 2/8/12 at 05:17 PM |
Ok sorry, mine wasn't as the ecu was right next to the Edis.
paulf
| posted on 2/8/12 at 08:03 PM |
PiP and SAW are shielded on the original installation, I have removed lots of Edis plugs in the past and they all had shielded connections.Microphone
cable is ok but usually quite flimsy, I use industrial shielded cable from work but have also thought that electric guitar leads would make a good
substitute as the better quality ones are quite substantial and designed to be hard wearing .
Paul
