xeandy
posted on 29/3/06 at 10:14 PM |
Yamaha R1 TPS
ok so ive just about finished setting up megajolt to run on my xe, all i need to do is connect up the TPS does anyone know which pin is what on the
sensor so that i can wire it up, or does anyone know where i could get a plug that will fit the R1 TPS?
cheers andy
Chaz
posted on 30/3/06 at 08:03 AM |
I've had no luck as of yet finding a connector for the R1 TPS sorry. But do have a question for you. Do you know where to get the special star
tool to fit the screws to remove the TPS?
tks
posted on 30/3/06 at 12:01 PM |
mhhh
its called Torx..if i'm right..
my bike engine used it to!
anyway watch out with TPS sensors..
because they are callibrated to the engine..
if you move it it will inject more or less fuel...
Tks
MrSandMan
posted on 30/3/06 at 07:20 PM |
Right then.
Looking into the TPS from where the plug would enter, with the two guides to the bottom and one to the top. So looking into where the throttle spindle
goes.
Left Hand Pin - Live Feed (5V from MJ)
Middle Pin - variable output (TPS)
Right hand Pin - Return Feed (Earth with MJ)
I couldn't find a plug so have soldered wires direct to the pins and then heatshrinked them all together. I have them filled the plug hole with
araldite. The protruding wires have them been fitted to a multiplug.I hoipe this helps.
xeandy
posted on 1/4/06 at 06:22 PM |
cheers mrsandman think ill be doing something similar
and i had a set of torx with holes in the middle as part of my halfords professional 150pc socket set so just used them so im sure they will probably
sell them hope that helps
