Author: Subject: throttle bods
theconrodkid
posted on 29/8/06 at 06:43 PM Reply With Quote
throttle bods
ive nailed the gsxr bods to my zetec/dcoe inlet manifold,the spacing is a little different tho,i can cut and extend the plain fuel rail pipes but the one with the fuel inlet on it,there isnt enough room/pipe to extend with the hex getting in the way.
so what have you lot done?
who cares who wins
pass the pork pies
Doofus
posted on 29/8/06 at 10:12 PM Reply With Quote
There's just enough room to do a cut and shut
I did it twice to get a feed and return and just used high pressure hose and fuel hose clips to do it. Works a treat..
Thats at DCOE spacing of the bodies
Paul
[Edited on 29/8/06 by Doofus]
theconrodkid
posted on 30/8/06 at 05:37 AM Reply With Quote
cheers mate,you may have slimmer clips than me
who cares who wins
pass the pork pies
theconrodkid
posted on 30/8/06 at 05:16 PM Reply With Quote
right got that bit sorted,anyone got a spare fuel T peice?.
what to do with the throttle linkage,bend or extend?
who cares who wins
pass the pork pies
Doofus
posted on 30/8/06 at 10:40 PM Reply With Quote
Extend the middle one bend the outer two.
I got an 8mm plastic T from B&Q I think. I keep meaning to replace it with a metal one but it's worked ok so far...a few thousand miles done.
Paul.
[Edited on 30/8/06 by Doofus]
theconrodkid
posted on 31/8/06 at 09:12 AM Reply With Quote
mmmmmmmmm plastic,i have an SVA to get through,donk know if they would like it and ,if yours are the same as mine,there is a groove near the ends with an O ring in
who cares who wins
pass the pork pies
matt_claydon
posted on 31/8/06 at 02:54 PM Reply With Quote
Conrod,
I gave up and splashed out in the end and bought an extra t-piece from a Suzuki dealer. Think it was about 30 quid though so not exactly locost
stevebubs
posted on 31/8/06 at 03:11 PM Reply With Quote
Bought a complete rail from Jenvey. Bolted on. Job done.
stevebubs
posted on 31/8/06 at 03:12 PM Reply With Quote
Bending tends to run the risk of bending the spindles.
I spot welded a couple of plates onto the existing ones.
theconrodkid
posted on 31/8/06 at 06:41 PM Reply With Quote
thought about damaging the spindles,was going to drill n tap 3mm,2.5 mm drill is to small for the tap,gave up and had a cuppa after that
who cares who wins
pass the pork pies
