Author: Subject: Power Commander || Adaptation
tks
posted on 17/1/07 at 09:15 AM Reply With Quote
Guys,
what happens if you select a file wich isn´t for your powercommander/bike.
Are you able to upload it?
Or should we just see it as a file wich a name what i mean to say no control is done for what powercommander it is.
Are you able to open a honda map? and load it into the R1??
reason i ask is on fleebay there are allot of Powercommanders some cheap some not so i just wanted to adapt it to my own bike. should be quet easy!
Tks
p.d. take in mind that many bike share coils, temp sensors etc..
posted on 17/1/07 at 09:31 AM Reply With Quote
In theory - I would say yes you can upload whatever file you want. But I doubt the bike original ECU could be modified by the Power Commander to give the correct running conditions you require.
tks
posted on 17/1/07 at 10:04 AM Reply With Quote
you are wrong :D
The power commander doesn´t change the stock mcu. it just adds or cuts time to the injection event.
For the spark it could do the same.
in fact if you have 4 coild and 4 injectors you only need 8 inputs and 8 outputs..
Tks
