Author: Subject: Bike carb help
jonno
posted on 23/1/07 at 04:15 PM Reply With Quote
Bike carb help
Hi all, Need a little advise please.
I'm doing a zetec conversion and went to a bike breaker today to get some ZX9 carbs, but then looked as CBR 600 carbs (2000 i think with a TPS and there 37mm)
I would prefer to go with the CBR 600's with the TPS would they be suitable for a standard 1.8 zetec ??
(i might put some 130 cams in at some point)
whitestu
posted on 23/1/07 at 04:26 PM Reply With Quote
I hope so!
I'm planning to use ZX6R carbs which are about the same size on a 1.8 Zetec.
Stu
Marlon
posted on 23/1/07 at 05:11 PM Reply With Quote
Do zx9's not have a tps on them? Mine did.
john.
Band Anyone?
Linky to SWMBO 's band
Linky to Brother in laws band
MKoc 1081
posted on 23/1/07 at 07:05 PM Reply With Quote
I'm using ZZR1100 carbs at 40mm ID with no TPS.
I'm going to attach the Ford TPS from the original inlet to the throttle pedal and see if that works.
darrenga
posted on 23/1/07 at 07:06 PM Reply With Quote
what size are the chokes on zx9's
jonno
posted on 23/1/07 at 07:08 PM Reply With Quote
40mm on the ZX9's i looked at.
I think i'm going to have a punt on the CBR 600's as there quite cheap
Can upgrade later if necessary
TangoMan
posted on 23/1/07 at 08:23 PM Reply With Quote
37mm chokes should be fine for a 1800 Zetec.
I think from memory they are OK to about 150bhp. If you were running Webers or Dellorto's you would probably be using 40's with 36mm chokes.
Summer's here!!!!
DarrenW
posted on 24/1/07 at 11:38 AM Reply With Quote
Ive heard of someone else having success mounting the TPS to the throttle pedal.
Im going to try and suss how to fit to the ZZR1100 throttle spindle - not looked seriously at it yet though. Im sure its easier said than done.
