Author: Subject: Fuel injection air intake
Thinking about it
posted on 26/2/07 at 09:38 PM Reply With Quote
In my picture archive is a pcture "air intake" Could you please have a look and answer the following for me?
1 Is it possible to dispense with item B as it seems all a little cumbersome for an air filter box although it does have a fancy flap arrangement inside.
2 if so can i then mount the fuel distribution unit elsewhere?
3 could I then fix an air filter straight onto C
It is a 1600 CVH engine with the pre efi system. Do you think it will go under the bonnet without any cut outs?
I know you will say fit carbs. But this works well and carbs being a greater expence could come later if necessary.
nitram38
posted on 26/2/07 at 09:54 PM Reply With Quote
[img][/img]
Confused but excited.
posted on 26/2/07 at 11:15 PM Reply With Quote
Speaking personally, I'm all for fancy flaps!
Thinking about it
posted on 26/2/07 at 11:26 PM Reply With Quote
Never mind the flaps. Do I bin it or keep it?
TangoMan
posted on 27/2/07 at 11:15 PM Reply With Quote
Is the 'fancy flap' not the fuel metering unit.
I thought those injection systems had an air metering unit (flap) which dictated how much fuel to inject.
Of course, I could be talking bourbles!!
Summer's here!!!!
posted on 27/2/07 at 11:20 PM Reply With Quote
The flap is what meters the fuel, so no you can't bin it if you want to keep the stock fuel injection.
Thinking about it
posted on 27/2/07 at 11:55 PM Reply With Quote
Thanks guys. Do you think it will fit?
