Author: Subject: Narrow band lambda sensor mounting
Steve Lovelock
posted on 26/3/07 at 05:16 PM Reply With Quote
I would dearly like to mount my lambda sensor in the engine bay. However my exhaust downpipes do not collect together until they are outside the engine bay. I could mount the sensor into a pipe that contains two of the outlets. Would it be stupid idea to do this or could I get away with it?
posted on 26/3/07 at 05:32 PM Reply With Quote
Are you suggesting having a cross-over type tube between the downpipes and putting the lamba sensor in that?
I'd worry about the "air" inside the tube not accurately reflecting what was going on inside the downpipes. However, I think that's me being silly. In practice it would probably work fine, the downpipes would be pressurised at different times so the pipe would be flushed through quite regularly.
Steve Lovelock
posted on 26/3/07 at 05:40 PM Reply With Quote
It is a 4 : 2 : 1 type of manifold and I was thinking of puting into one of the '2' sections.
TangoMan
posted on 26/3/07 at 06:03 PM Reply With Quote
I would do it properly. A narrowband sensor is already a compromise, why water it down even further.
With only 2 cylinders feeding, each will have a have 50% effect, with all 4 they will only have 25% effect.
See my maths are very good
I personally would (well I did) feed it through the side panel to fit from the inside if the pipe so it is protected. It actaully looks quite effective.
Summer's here!!!!
