andrewturner
posted on 19/4/07 at 07:26 PM |
TPS????
I am busy fitting a Toyota 4age 20V.
The TPS that came with my motor was busted what replacement part should I use and what ECU should I fit?
andrewturner
posted on 19/4/07 at 07:43 PM |
TPS OR MAP
wHICH IS BETTER
posted on 19/4/07 at 08:55 PM |
quote: Originally posted by andrewturner
wHICH IS BETTER
Depends!
For a mildly tuned road engines running a single throttle body and plenum, MAP gives you better indication of engine load.
MAP is less suitable for tuned engines with long duration cams and individual throttle bodies because getting a stable vacuum signal is more
difficult.
