Author: Subject: Swirl pot with in-tank pump
Alan B
posted on 22/7/08 at 01:17 PM Reply With Quote
Would this be OK?....using a standard high pressure in-tank pump within a swirl pot? Obviously the swirl pot doesn't exist yet so I'd have to design it to suit.
Alan
Paul TigerB6
posted on 22/7/08 at 01:52 PM Reply With Quote
In a similar way to the ZX10R injection pump you mean?? Have a look here if so as it may help
Alan B
posted on 22/7/08 at 02:09 PM Reply With Quote
Paul, yes sort of....I was wanting to put my high pressure pump within a seperate swirl pot in the engine bay rather than within the tank.
Basically I'm going to have a mini fuel system complete in the engine bay that is fed at low pressure from the main tank. I think the difference is that the high pressure pump is usually outside the swirl pot.
Hope that clarifies my question a bit.
Cheers, Alan
Paul TigerB6
posted on 22/7/08 at 02:15 PM Reply With Quote
Gotcha, cant see any reason why the pump cant be fitted in a swirl pot of suitable design as it would within a fuel tank then - so long as the low pressure side is sufficient to keep the swirl pot filled your plan sounds fine to me.
blue2cv
posted on 22/7/08 at 06:14 PM Reply With Quote
Ok, i'll ask, why?. Can you not simplify your setup and have the inj pump in the main tank
Werner Van Loock
posted on 22/7/08 at 06:43 PM Reply With Quote
Wouldn't do it, on the stylus forum there's one that has fried 3 pumps already and probably because of the temperature in the engine bay en less fuel to cool it.
philw
posted on 22/7/08 at 06:47 PM Reply With Quote
Mine is in the engine bay, i have had no problems with it.
Must try harder
v8kid
posted on 22/7/08 at 08:06 PM Reply With Quote
I've got my high pressure pump external to the tank and I would not do it this way again. You need low pressure pumps to feed the swirl pot (I had to use 2 to get the flow right) and the plumbing and electrics are more complex, heavy and expencive.
Pump in the tank seems to be the way to go to me and I'd gladly sell or swap my Bosch 044 and twin Facet red top setup for an in tank pump.
Alan B
posted on 22/7/08 at 08:34 PM Reply With Quote
Thanks guys good input. My reason for even considering it is that my tank is fairly tall. However I guess I could extend the pump bracket, piping and wiring so that it reaches closer to the bottom.....I suppose that would work Ok?
