quote: Originally posted by beaver34
where does the throttle body go? was wandering as didnt know if that effected how efficent the setup was as no1 would see the air first and 4 last if
it was on the end
I would use a set of 45mm DCOE style jenvey's on Jenvey/DCOE inlet manifold (same as if the engine was N/A) then make an inlet plenum to feed
the throttle bodies, some care as to be taken when designing the plenum to insure near equal flow to each of the 4 throttles (this is only a problem
when full throttle), jenvey do make a turbo plenum for this purpose but it is expensive.
In my opinion the log type manifolds often used on zetec's in locost cars are rubbish, the build quality is poor and no thought appears to have
been given to air flow, but i do recognize space restrictions hamper a proper design.
