ozzy69
posted on 30/11/13 at 05:02 PM |
Thanks phill.
ozzy69
posted on 30/11/13 at 06:21 PM |
Right have checked everything you said phil and screwed the pots back jumper is (3-4)set to VR OUT I will try and send you my msq .
[Edited on 1/12/13 by ozzy69]
ozzy69
posted on 1/12/13 at 11:49 AM |
Now i have put the pots back i am now not getting any type of signal for rpm anyone no why this///Now getting a signal but i am confused if i am
getting a steady rpm(with plugs out) does this mean i am getting a signal from vr??
matt_gsxr
posted on 1/12/13 at 03:13 PM |
I'd follow Phil's instructions to the letter. He is the king of MS and has offered to help.
ozzy69
posted on 3/12/13 at 12:51 AM |
Problem solved and now have spark thanks to phil this man is a star and i really appreciate the time and effort he has spent helping and solving my
problem.
omega 24 v6
posted on 3/12/13 at 06:26 PM |
So its going??
What was the problem I looked at your msq and although I'm an MS1 man and its an MS2 it looked Ok as far as I could see.
ozzy69
posted on 3/12/13 at 09:41 PM |
Well i am now getting spark,not really sure but spark plugs where cracked, but she still wont start and i am so sick i feel like throwing in the
towel and ripping the whole lot out (ms and engine) i think the car is just a jinx.After getting spark i found out after a day of charging batterys
and winding over that it had a low pressure pump so today i got a high pp then after more winding over found that the fuel reg was set to 1 bar now
after setting it to 3 bar the starter packed up luckly i had a spare so fitted that and then the car started backfiring throw the inlet now swaped
over spark output a and b and she offerd to go but still no joy haha wish ad never seen the thing.
omega 24 v6
posted on 4/12/13 at 12:05 AM |
Well you are almost there now so don't give up.
ozzy69
posted on 4/12/13 at 12:27 AM |
A few beers calmed me down haha I am hoping the the sparky has wired injection bank one into 1 and 2 and bank b into 4 and 3 as it should if i am
right be banks 1 into 1 and 4 and bank b into 2 and 3 so fingers crossed this is the problem.
ashg
posted on 4/12/13 at 11:47 AM |
are you giving it a bit of throttle when trying to start? if there is no map on it chances are it will need a bit of throttle to keep it running, the
cold weather wont be helping the situation. i spent a good month of evenings reading up on ms before i installed mine, they are not an easy work out
of the box solution if you cant be bothered to read up on the subject.
as for injector wiring it wont matter too much, it will just idle a bit rough, the fuel will just sit on the back of the valve until it opens so its
not a big deal.
Haynes Roadster (Finished)
Exocet (Finished & Sold)
New Project (Started)
scudderfish
posted on 4/12/13 at 12:26 PM |
Make sure you really really really have the right sides of the coil pack connected to the right feeds from EDIS/MS. When I was doing my V8 I had them
swapped over on one pack. 4 cylinders were sparking at the right time, 4 at the wrong. Flames out of the inlet were the result Looking at only
the coilpacks and spark leads it looked like I had it all correct for the firing order, but the coils themselves were out of order.
ozzy69
posted on 4/12/13 at 03:35 PM |
not a big deal.
No had not gave it throttle but just after she had offered to start i gave it a bit then it would not offer again so i
calibrated the tps just encase this was the problem but no,I had bought the car only for the car i did no care about the engine or management as i had
planed to use a full zetec turbo with fiesta rs turbo management but after finding out that all i had to do was wire and program the ms-2 in there was
no point fitting another engine when most of the hard work had been done.I have spent every single night reading all about ms since i got the car
trust me first thing in the morning before work and last thing at night. The wiring into the coil is bang on as i went over this with phil but the
fact that it was backfiring throo the inlet is a bit of a worry so next thing i will check is the timing but my injectors are infact wired bank 1
into cylinders 1-2 and bank 2 into 4-3 and my firing order is 1243 so i take it that bank 1 should be (1-4) and bank 2 (2-3)?
[Edited on 4/12/13 by ozzy69]
matt_gsxr
posted on 4/12/13 at 05:54 PM |
As above, backfire won't be caused by injector timing.
I can run batch (i.e. 1 squirt per revolution for all 4 cylinders) and it works fine.
You must surely be sparking when an inlet valve is open.
ozzy69
posted on 4/12/13 at 06:49 PM |
Well that has eliminated another thing thanks,i am dreading the timing is out but it has not been touched so should not be but,hears my msq does can
any one tell me that it is right for a 2.0 blacktop zetec running gsxr1000 bodie's
http://s956.photobucket.com/user/ozzy6969/media/msq_zps125bf6df.png.html?filters[user]=137909182&filters[recent]=1&sort=1&o=0
coyoteboy
posted on 4/12/13 at 08:45 PM |
Cheer up. Megasquirt is never a plug and play solution unless you buy it pre-wired and pre-prepped for the sensors you have, plus pre-mapped with a
base map. It's going to take time and effort. At least if it's using new harnessing it has minimal problems built in - im running an MS on
24 year old OEM wiring. That's not fun
To be honest I'd expect to sink several full weekends into getting an MS running properly for your first time, and probably a tank of fuel or
two - that's the point of it almost, to learn how it works and why. If you want a cheap and easy solution, MS isn't it.
Sounds to me like you have the wasted spark reversed. Plus ITBs are rarely easy to get started on a base map.
coyoteboy
posted on 4/12/13 at 08:56 PM |
Injector banks are not really critical. only spark. IF your firing order is 1-2-4-3 you need to have spark A wired into 1 and 4, and spark B wired to
2 and 3. I can switch my injector wiring around between any combination of bank/batch and see almost no difference in running (slightly less stable
idle as all 4 off one driver but no different when paired strangely between two drivers).
ozzy69
posted on 5/12/13 at 01:54 PM |
Well done a compression test today and this is how it went cylinder-1(75psi),2-(25psi),-3-(150psi) and 4-(150psi) just gets better so this was my main
problem to start with so engine out job but thanks for all the help from everyone.
coyoteboy
posted on 5/12/13 at 02:20 PM |
Oh dear, not good news! Good luck getting it back up and running, give us a yell if you continue to have issues!
ozzy69
posted on 5/12/13 at 02:22 PM |
Thanks will do.
ozzy69
posted on 5/12/13 at 04:21 PM |
Just of the record if my engine is fooked(well bent valves or h gaskit) before reading up about it if i was to turbo the blacktop after fixing it or
just getting another engine will this make it alot more harder for me getting ms setup with a turbo'd engine compared to just running gsxr
bodies?
coyoteboy
posted on 5/12/13 at 05:02 PM |
Only from a mechanical point of view, from an MS viewpoint it will change your mapping process a little but otherwise it should be no different -
you're just increasing the kpa range
