<<  1    2  >>
Author: Subject: physics questions - lifts
trogdor
posted on 18/1/07 at 12:32 PM Reply With Quote
i doubt lifts have crumple zones, but i think they have piston/dampers at the bottom of the shaft so if the lift does somehow manage to fall all the way it will absorb the impact enough so the peeps inside should survive.
jlparsons
posted on 21/1/07 at 09:53 PM Reply With Quote
Apparently lifts have very big spring loaded brakes that are kept off only by the pull of the cable, so if the cable is cut the brakes jam into the walls with so the lift can fall a few feet at most. Apparently.
Volunteers?
Any resemblance to real persons, living or dead is purely coincidental. Some assembly required. Batteries not included. Contents may settle during shipment. Use only as directed. No other warranty expressed or implied. Do not use while operating a motor vehicle or heavy equipment. Subject to approval, terms and conditions apply. Apply only to affected area. For recreational use only. All models over 18 years of age. No user-serviceable parts inside. Subject to change. As seen on TV. One size fits all. May contain nuts. Slippery when wet. For office use only. Edited for television. Keep cool; process promptly.
trogdor
posted on 22/1/07 at 09:49 AM Reply With Quote
yep i have heard that too, i beleve lifts have to have at least 8 seperate cables all capable of supporting the lift on thier own, then they have mechanical automatic brakes and if those all fail their are still those dampers/impact absorbers to hopefully allow anyone inside to survive if the lift does fall
<<  1    2  >>
