Author: Subject: Haynes roadster wishbones to locost chassis
ZEN
posted on 9/11/08 at 11:23 PM Reply With Quote
Have the Ron C. and Chris G. books. I'm currently building a book chassis and want to use the front Sierra uprights. Are the wishbones from the roadster suitable for a Ron C. locost chassis?
[Edited on 9/11/08 by ZEN]
My YouTube channel Cars, bikes - track days, motorsport, sim racing and more.
Chippy
posted on 10/11/08 at 12:01 AM Reply With Quote
The roadster chassis is wider than the standard Locost one, so will be too short. If you are making them you could of course make them longer, in which case they would be OK, or at least thats how I see it. Cheers Ray
ashg
posted on 10/11/08 at 07:39 AM Reply With Quote
just build a haynes roadster problem solved :-)
the big difference between the locost wishbones and the haynes ones are that the maxi joints are angled at 10deg as is the top transit link to counteract the ofset on the sierra hub that is refered to as anit dive.
on a different note you could use the locost type wishbones and rallydesigns light weight hub as another option.
unless you know alot about suspension i wouldnt extend the haynes wishbones as it will cause all sorts of handelling nasties.
it may be worth waiting for chris g to come along and give some input or give mk a call
[Edited on 10/11/08 by ashg]
Haynes Roadster (Finished)
Exocet (Finished & Sold)
New Project (Started)
Taz Surfleet
posted on 10/11/08 at 12:56 PM Reply With Quote
Thought you could buy wider MK style bones from Ralley design to fit the locost chassis !
James
posted on 10/11/08 at 05:19 PM Reply With Quote
You've got the books! Check the dimensions to see if they're the same.
I suspect they're not (I would guess 1" longer on the Roadster).
And the width between mounts may be different.
What's wrong with the R.Champion ones?
cheers,
James
chrisg
posted on 10/11/08 at 06:13 PM Reply With Quote
Well the Locost wishbones are made for the Cortina upright.
If you want to use the Roadster wishbones you'd have to replicate the pivot positions.
There's much more to suspension design that means swapping wishbones from one design to another is not really ever ideal,
Chris
[Edited on 10/11/08 by chrisg]
Note to all: I really don't know when to leave well alone. I tried to get clever with the mods, then when they gave me a lifeline to see the error of my ways, I tried to incite more trouble via u2u. So now I'm banned, never to return again. They should have done it years ago!
ZEN
posted on 10/11/08 at 09:33 PM Reply With Quote
I woud do that exept the loco chassi is alomost ready to be welded...
The rallydesign light weight hub are not an option, as my are offlimit for by budget. And want to use if sierra hubs as there are 2 pairs of them sitting in my shed.
I thhink is the time for me to start reading the Alan Stanifor books I ordrered recently.
[Edited on 10/11/08 by ZEN]
ZEN
posted on 10/11/08 at 10:51 PM Reply With Quote
Refering to this? http://www.rallydesign.co.uk/advanced_search_result.php?keywords=locost
