indyian
posted on 21/11/08 at 03:51 PM |
megajolt could not open port
trying to put map on my megajolt for 20 zetec and having probs when it tells you to send map it comes up at bottom of screen port could not open
anyone have any ideas why its driving me mad many thanks ian
rayward
posted on 21/11/08 at 04:11 PM |
another program is using the com port!
close all other running programs (mobile phone software etc)
check bottom right corner of your screen (if your on xp) see if anything is running there
hth
Ray
Paul (Notts)
posted on 21/11/08 at 05:46 PM |
is it set to the correct com port.
With the megajolt plugged into the laptop - go to device manager and find what port the megajolt is plugged in to.
Then go to the menu on megajotl software and set the com port.
I have to use a usb to serial converter and have 4 usb ports on the lap top. Each time I use it I have to set the megajolt to the correct com port.
Paul
[Edited on 21/11/08 by Paul (Notts)]
indyian
posted on 21/11/08 at 06:32 PM |
thanks for the help i tried them but no luck even with right port still can not open port any outher sugestions many thanks ian
Paul (Notts)
posted on 21/11/08 at 06:41 PM |
Go to the forum on ..
http://www.autosportlabs.org/
and ask there. some one will help.
Paul
edit - does it show any sings of being connected eg - visible under devcie manager, able to read map from megajolt, able to see MAP ouput/ or TPS
ouput.
What computer/laptop is it.
any other device using the same com port under device manager.
indyian
posted on 21/11/08 at 06:52 PM |
no it wont let you read off or put on i am also using adapter for usb dose this change things
Mole
posted on 21/11/08 at 06:54 PM |
Is megajolt working i.e is it controlling the ignition advance or have you not tested it on the engine yet. I had this problem (not tested on engine)
and in my case I had the rom and transistor array in the wrong sockets.
1st thing to do is see if it works on a computer with a serial port to elimate the USB adapter.
[Edited on 21/11/08 by Mole]
Paul (Notts)
posted on 21/11/08 at 06:57 PM |
is the megajolt connected to a power source?
Mole
posted on 21/11/08 at 06:59 PM |
Okay 2nd thing to do is see if it works on a computer with a serial port to elimate the USB adapter. ![](/images//smilies/smile.gif)
indyian
posted on 21/11/08 at 07:03 PM |
yes it dose have power and we are trying to test it on car not yet had it running on ecu and the adapter is fine i had it tested erlier at shop as we
dont have anything hear that will take serial port once again thanks for help but still no luck lol
indyian
posted on 21/11/08 at 07:37 PM |
now its saying time out reading cylinder count still wont let you do any thing ![](/images//smilies/mad.gif) ![](/images//smilies/mad.gif) ![](/images//smilies/mad.gif) ![](/images//smilies/mad.gif) ![](/images//smilies/mad.gif)
Paul (Notts)
posted on 21/11/08 at 08:05 PM |
MY lap top at wotk will only recongnise some things if they are connected BEFORE the computer is turned on. Try restarting the computer with the
megajolt connected and powered up
ps 3 pints of beer and typing is getting hard
indyian
posted on 21/11/08 at 08:07 PM |
no worries thanks for your time i try that
posted on 21/11/08 at 10:15 PM |
After a few pints most things get hard. Except the things that should be ![](/images//smilies/wink.gif)
