Benzine
posted on 27/11/08 at 11:28 AM |
Megatune gauge changing
I'm using megatune 2.25 at the moment and TPS isn't one of the standard gauges (which I do want there)
I found this thread about editing the .ini file which I tried but still the gauges show the same
http://www.umsforum.mini-cooper-clubman.de/YaBB.pl?num=1220958094
So for this:
;Gauge Setup 0
gauge1 = RpmHiResGauge
gauge2 = mapGauge
gauge3 = egoCorrGauge
gauge4 = cltGauge
gauge5 = ego2Gauge
gauge6 = accelEnrichGauge
gauge7 = lambdaGauge
gauge8 = advanceGauge
I edited to this:
;Gauge Setup 0
gauge2 = mapGauge
gauge4 = throttleGauge
gauge5 = ego2Gauge
Then saved the file. Nothing changes when I load megatune though, is there something fundamental I'm doing wrong? When I look at the ini
information in the megatune configurator it's showing that it's changed but it doesn't do anything
[Edited on 27/11/08 by Benzine]
The mental gymnastics a landlord will employ to justify immoral actions is clinically fascinating. Just because something is legal doesn't make
it moral.
omega 24 v6
posted on 27/11/08 at 12:34 PM |
can you not just right click on the gauge you want to change and select the new one you want??
EDIT to add on my one I right click the =gauge I want to change then "swap to" then select from the HUGE range there is there.
[Edited on 27/11/08 by omega 24 v6]
Benzine
posted on 27/11/08 at 12:44 PM |
o lawd
Thanks omega!
it moral.
omega 24 v6
posted on 27/11/08 at 12:52 PM |
big_wasa
posted on 27/11/08 at 05:08 PM |
does that mean its running ?
Benzine
posted on 27/11/08 at 05:41 PM |
It's so close At the moment it's turning over and spluttering as if it wants to run but not quite
I installed the trigger wheel as per the intructions, I'm getting really strong sparks and the injectors are working. I'm guessing
it's a timing thing but I don't know how to go about fixing it...
it moral.
clairetoo
posted on 27/11/08 at 09:31 PM |
Get it cranking on the Edis , and check that you have a spark at 10 degree's before TDC - after first checking that you have TDC marked
accurately on your trigger wheel , and you are checking the right cylinder
Its cuz I is blond , innit
Claire xx
Will weld for food......
