Steve Lovelock
| posted on 14/12/08 at 06:16 PM |
LC1 settings AFR or Lambda
Just starting to set my new LC1 up and am not sure if I should set it on Lambda or AFR with the LM programmer when using it with a MSnSE?
mark chandler
| posted on 14/12/08 at 06:28 PM |
You need to open up megatune and under file settings open up configurator.
There is a windows type drop down tree, open this for Lambda then match here.
For myself I used autotune in megatune but played around with the variables to widen the scope then closed down as the tune got closer. Took me
hours.... but that was lots of driving
Regards Mark
BenTyreman
| posted on 14/12/08 at 08:06 PM |
Lambda or AFR in the LC-1 programmer makes no difference. It just specifies the output voltage at a particular AFR. You can specify the AFR as either
a ratio or as lambda.
The MS interpretation of the voltage is entirely separate. MS expects 0V to be 10:1 and 5V to be 20:1. This is not the default setting for the LC-1.
omega 24 v6
| posted on 14/12/08 at 11:20 PM |
I thought it was??? If you have output 2 programmed into the LC 1 is it not 0 to 5 volts then??
BenTyreman
| posted on 14/12/08 at 11:51 PM |
At the time I bought my LC-1, the default for output one was to emulate a regular narrowband sensor and the default for output two was 0V = lambda 0.5
and 5V = lambda 1.5.
