Moorron
posted on 18/12/08 at 10:51 AM |
Sump chop ZX12R suggestions
Hi guys, hope you are all working hard and not eating too much quality street.
Looking for some advice on sump chopping, I cant find any on the site other than a few pics of the outsides of some diy jobs. I suppose its in general
so may help others but in my case its regarding the ZX12R bike sump.
First off, can you buy a sump baffle for the ZX12R engine? Cant find one anywhere so I might have to make my own (good job I work with a turret
punch). Does it need one? It’s a very deep sump and it would take some sideways G forces to get the oil up the side of the crank and expose the oil
pickup.
Regarding the sump chop, I need to remove about 40mm from mine to get it back to the previous engines sump clearance which seemed fine over speed
humps and the like. This 40mm includes the oil drain plug and tangs on the bottom of the sump so I only need to remove about 25mm from the actual oil
carrying part of the sump. I can alloy weld at home so this part isn’t a problem, but is it just a matter of cutting the bottom off and welding a new
plate of alloy on and then rewelding the drain plug on the side? I will need to remove the same amount off the oil pickup pipe but again i am assuming
this is just a case of a hacksaw and angle grinder?
The other thing I have seen (small pic of hellfire’s sump) is the sump capacity has been increased by welding a box on the sump to make it like a
typical car sump and box shaped unlike the bike ones which need clearance for the exhaust. Again I can do this but what internal baffles have been
added or is it now just a huge box holding the oil.
I want to track the car in 2009 for a few days but its mainly used on sunny summer days out on the local country lanes.
Andy.
Sorry about my spelling, im an engineer and only work in numbers.
eznfrank
posted on 18/12/08 at 12:07 PM |
I had Martin Keenan do my ZX12 sump chop for a very reasonable £45 and a very neat job it is too with internal baffle. Mine looks similar to how
Hellfire did theirs and the sump plug is moved to the side.
He effectively chopped off the bottom and used the sidewall as the baffle with a box made on the other side.
I had to chop around 25mmn off the pick up but it's only plastic so a hacksaw will do the job.
Moorron
posted on 18/12/08 at 12:47 PM |
have you got any pictures of it?
Did you fit a baffle between the sump and engine? or are there only baffles 'inside' the sump?
eznfrank
posted on 18/12/08 at 01:24 PM |
Not get any pics to hand, could get one no probs but would be a while as off to Vegas on Saturday and running round like a nutter trying to get stuff
done.
There's is only a vertical baffle and no horizontal one below the engine. I know some have done this but Martin and if i remember correctly
Malc (Yorkshire Engines) told me not to bother as the pickup is in the right place anyway (ie towards the rear of the sump when in the Indy) to
minimise potential oil surge issues.
eddbaz
posted on 18/12/08 at 02:20 PM |
obviuosly it depends on budget but I fitted a sump with a swing pickup which I got from ab performance,top piece of kit and if your thinking of doing
plenty of trackdays a worthy investment in my opinion.
sorens2
posted on 18/12/08 at 03:24 PM |
Mine is dry sumped but I don´t know what it costs.
That would be the best way to do it.
Or second best is a swingarm. ABperformance for example.
Søren S2
eznfrank
posted on 18/12/08 at 05:56 PM |
AB have a sump with 360 degree pick up for a ZX12 on the bay at the moment - Not cheap but looks like a cracking bit of kit.
Clicky Clicky
[Edited on 18/12/08 by eznfrank]
yorkshire-engines
posted on 18/12/08 at 06:31 PM |
Andy,s sump kit is very good we developed thisi for some time and works well
but i have seen Martins sump mod and thet was good as well
athoirs
posted on 18/12/08 at 07:04 PM |
some pics of mine
http://www.locostbuilders.co.uk/viewthread.php?tid=40225
[Edited on 18/12/08 by athoirs]
eznfrank
posted on 18/12/08 at 08:37 PM |
quote: Originally posted by athoirs
some pics of mine
That's basically the same as mine. Not sure you'll see this athoirs but what probs did you have with the ZX?? (as per your previous
post?)
Moorron
posted on 18/12/08 at 10:58 PM |
Thanks for the pics, can i confirm that the original horizontal part of the sump has only the 3 holes drilled into it that i can see on the pic and
also the square cutout to let oil get to the pickup?
if it is the case my own diy job will be nice a quick to do, and i dont think i need to shorten mine as much making me feel safer knowing yours is
fine.
cheers
