Author: Subject: 10mm diameter copper micro-bore pipe for fuel line
Steelman
posted on 8/1/09 at 10:00 AM Reply With Quote
Is it okay to use 10mm diameter copper micro-bore central heating pipe for the fuel line
Pdlewis
posted on 8/1/09 at 10:01 AM Reply With Quote
thats what im using
Build Photo Album
Updated 05/02/2009
v8kid
posted on 8/1/09 at 10:02 AM Reply With Quote
Me too
posted on 8/1/09 at 10:20 AM Reply With Quote
If 8mm microbore is okay I would have thought the only down side to 10mm is that it's quite big
Mr Whippy
posted on 8/1/09 at 10:30 AM Reply With Quote
I used 8mm on the Falcon and the buggy, no problems. You can solder olive compression rings to the ends to act like a flare and help prevent the hose being pulled off
[Edited on 8/1/09 by Mr Whippy]
tegwin
posted on 8/1/09 at 10:38 AM Reply With Quote
Thats a bit high tech... I just used 3 jubilee clips on ach end
www.verticalhorizonsmedia.tv
Mr Whippy
posted on 8/1/09 at 10:41 AM Reply With Quote
possibly but it sure looks better
posted on 8/1/09 at 10:49 AM Reply With Quote
Ooooh I like it! I was going to epoxy a bit of string round the end of the tube as a DIY flare. But some olives soldered sounds much nicer....
Bigheppy
posted on 8/1/09 at 06:03 PM Reply With Quote
just put a flare on the end using a brake flaring tool my set has various sizes.
LBMEFM
posted on 8/1/09 at 06:53 PM Reply With Quote
The subject appears to be done to death, but I agree I used micro-bore pipe and it's perfect.
