Dave Bailey
| posted on 14/1/09 at 11:34 PM |
fuel pump requirements
Anyone know what the fuel rail pressure should be for a 2.0 Zetec (st170) 180 ish BHP? In addition pump requirement ltr/hour? I was using a Subaru
Impreza fuel pump but tonight it went up in smoke! so I need to a new one rather than buy another second hand. The Sabaru was an in tank pump but I
plan to use an external pump now!
thanks
Dave Bailey.
bigrich
| posted on 14/1/09 at 11:52 PM |
FI line pressure is usually about 3.0 bar (44 psi) for multi point systems,
I would look at a Astra GTE 16v pump or similar.
Dave Bailey
| posted on 15/1/09 at 12:00 AM |
thanks
Dave B
JAG
| posted on 15/1/09 at 08:31 AM |
Most systems run at 3 bar.
Choose a FI pump that is fitted to a car with a similar FI system and power output, or maybe slightly higher power, and you shouldn't go far
wrong.
It is possible to calculate the engines needs but it's long winded and this approximation works.
[Edited on 15/1/09 by JAG]
Justin
| posted on 15/1/09 at 10:00 AM |
Yup. Choose an EFI car of a similar BHP and similar vintage (likely to have a similar fuel requirement per BHP).
Job done.
3 bar is standard...
