flak monkey
posted on 17/1/09 at 04:37 PM |
It lives again
After getting rather worried about getting my panther running on MS it all went relatively smootly today.
Found out that my temp sensors (although apprently both the same) gave wildly different temp readings and impedances. Seem to have fixed this
relatively well with easy therm, though they are still a bit out and I am not sure if this is going to cause a problem or not yet.. (reading about
5deg low)
Other than that hiccup it was painless. Other than the obligatory fuel leaks (minor!).
Even started first time, all i was doing was looking for a cranking pulse, and she fired up after a couple of seconds. Took me by suprise as I was
expecting to have to tweak lots of things to even get it to cough!
Went to start adjusting the balance of the throttle bodies (they are waaaaaay out) and the neighbour came and complained. Bearing in mind it had been
running for under 3 mins at tick over I think thats a bit unfair....
Whats left is to tidy all of the wiring up and fix everything down properly (see pics). Other than that its pretty much ready to start tuning.
Heres some pics of the current state (literally!).
Jobs for tomorrow are:
1) tidy all of the wiring up and clip it in.
2) tidy the fuel lines up and make some brackets to hold the injector feed.
3) Chop a bit out of the nose to clear the injector feed pipe.
4) Connect throttle cable
5) Fix down ECU
What I would really like are some proper injector, TPS and temp sensor connectors. No idea where to get the temp ones from though
Sera
http://www.motosera.com
afj
| posted on 17/1/09 at 04:40 PM |
go tell your neighbour to 'do one'
eerrrrrrrrrrrrrrrr
stevec
| posted on 17/1/09 at 04:45 PM |
Well done David.
Steve.
omega 24 v6
| posted on 17/1/09 at 05:27 PM |
Jeezo your neighbour must be a right PITA
big_wasa
| posted on 17/1/09 at 05:42 PM |
David what plugs are you after ?
I have a gsxr tps and plug and a couple of others kicking about. I dont have any spare injector plugs but they are common to lots of bikes. Being gsxr
they will be Denso injectors ? I know these are fitted to Yam R1's and others.
omega 24 v6
| posted on 17/1/09 at 05:46 PM |
Ooops should also add well done Flak. Did you use any shielded wires at all if so on which items. You'll see from my other post that I'm
still having problems
chris_smith
| posted on 17/1/09 at 05:57 PM |
well done fantastic news, i guess you and the neighbour have never seen eye to eye, to come round so quick is ridiculous, anyway you can annoy him
more once its on the road
chris
A1
| posted on 17/1/09 at 06:01 PM |
nice one!
neighbors only exist to complain...we got tonnes of gip from them cause we used to start the tvr and reverse it out the garage a bit when working on
the indy...
zilspeed
| posted on 17/1/09 at 06:10 PM |
My neighbour and I hardly speak, but you can sense a slight atmosphere of grinning and bearing it tolerance from them. I do go out of my way to not
cause hassle, but that's me.
The other day I managed to catch him for long enough to inform him that the overflow from his bathroom had been running for months and I was just
letting him know as I see it every time I leave and enter the garage. I also pointed out to him all of the problems it was bringing with it.
we're both detached, so it was no skin off my nose either way.
Today, I was astonished when he went ever so slightly out of his way to wave hello as he left to go out.
Only to return 10 minutes later with a plumber who fixed the overflow.
It's amazing how much difference a tiny bit of good will on both parts will make.
I suspect that me and my neighbour are now 'good' for a while again.
flak monkey
| posted on 17/1/09 at 06:19 PM |
I am running fuel only. But I am running sheilded wire from the coil to ms unit for trigger input (4 core metal braid sheilded, can probably get you
some from work if you want some? to try) Also got a supressor on the coil.
I'll have a look at your log file in a min.
Sera
mr henderson
| posted on 17/1/09 at 08:17 PM |
Or better still, go round with a bunch of flowers or a case of beer or something. Much better than aggression, and usually a lot cheaper.
People hate to think they are being ignored or their feelings being ridden over roughshod. All you need to do to correct the situation, usually, is to
show that you care what they think.
John
matt.c
| posted on 17/1/09 at 09:15 PM |
You havent been down my road then..
Well done flak. Want a race now?
flak monkey
| posted on 17/1/09 at 09:23 PM |
John
Tried that approach last year. As far as I am concerned I am not doing anything wrong. I am not making excessive noise, and 3 mins of running is
hardly long is it? Its also the first time the car has run for 3 months! Its not like its every day! Next time he is getting told where to go, but I
am not going out of my way to make a lot of noise. I was polite today.
The blokes impossible to reason with and is just a miserable old git with sweet FA better to do.
Sera
omega 24 v6
| posted on 17/1/09 at 09:51 PM |
tell him it's a toss up betwen your two main interests.keeping pigs in the back yard or the car LOL
mr henderson
| posted on 17/1/09 at 10:56 PM |
John
I wasn't trying to suggest you might have done anything wrong, and you are the guy on the spot, so I'll bow to your judgement.
John
flak monkey
| posted on 18/1/09 at 04:53 PM |
Back on topic, been for a short drive around the village today, seems to be ok but running very rich.
Did a bit of a data log, now off to have a looky
Sera
