flak monkey
posted on 18/1/09 at 06:36 PM |
Megalog viewer help
I am using alpha-n, and am looking at my datalog in megalog viewer.
How is the tps shown and how do i get megalog viewer configured right?
Am i right in thinking that MS logs tps as a percentage under the header 'TP'? If so, how do i get megalog viewer to translate this into
the adc which is used for the VE table y-axis?
I have attached my log and ms below.
Sera
http://www.motosera.com
flak monkey
| posted on 18/1/09 at 06:37 PM |
msq file for datalog above
Sera
flak monkey
| posted on 18/1/09 at 06:45 PM |
Think, i answered my own question, am i right in thinking its in custom field, then change he plot to TPadc?
Sera
vinny1275
| posted on 18/1/09 at 07:08 PM |
You know that talking to yourself is the first sign of madness?
omega 24 v6
| posted on 18/1/09 at 07:52 PM |
OK David here's how mines is setup at the moment (I believe it to be right)
To get TPadc go to options>y axis fields>tick tps adc
I also have calculated fields>optional fields> tick tp adc
When you open the ve analizer you need to set up your max and min TP adc settings in the bottom right of the popup window
Also you need to make sure you are analizing against the proper AFR or ve table bins ( the top right screen table in ve analize) I have mine set to
"default AFR" at the moment.
You also need to set up your wideband or narrow band in the calculated fields>wideband 02 AFR AND wideband 02 lambda menu as well.
Also remeber that if you accept the new table to save msq or save as msq and then go into megatune and reburn the new msq to the squirt before doing
your new datalog so that you are comparing the correct msq when you do your next analize.
brianthemagical
| posted on 18/1/09 at 10:24 PM |
I'm not sure if i understand fully, but, in the msq map the load sites are in a percentage of load derived from the msq settings, and you would
like to see this value in the data log? If so then you need to click on one of the parameters or empty slots on the left, such as rpm and that kind of
thing, and select load. Your datalog didn't have the load in the options tho, whereas my datalogs do.
flak monkey
| posted on 19/1/09 at 12:50 PM |
Waaay ahead of you there! You ought to hear me muttering away to myself in the garage!
Thanks guys, think I have it sorted now. Time for some nice weather so I can get out for some decent legth drives!
Sera
