Author: Subject: SVA and bolt specifications
gy351100
posted on 23/1/09 at 07:20 PM Reply With Quote
Hi all
Why can we not use grade "S" bolts instead of grade "8.8" as they are of the same tensile strength.
I have built my car to use UNF bolts which, as I understand, are only available in grade"S"
Metric bolts are in grade "8.8" but not all nearest equivalent sizes are compatible.
I can find no reference to grade "8.8" in the inspection manual eccept for the seat belt mounting
[Edited on 23/1/09 by gy351100]
blakep82
posted on 23/1/09 at 07:23 PM Reply With Quote
i'm sure it says 'equivalent strength' doesn't it?
________________________
gy351100
posted on 23/1/09 at 07:27 PM Reply With Quote
SVA bolts
Hi
But where in the manual does it say "equivalent strength"?
blakep82
posted on 23/1/09 at 07:34 PM Reply With Quote
it says
"A suitable single bolt fixing of adequate strength would be, for example a bolt of at least 11mm (7/16" diameter of grade 8.8"
fail point is a bolt of inadequate strength
it just says for example, fo find out what tensile strength an 8.8 grade metric bolt is, and then find a imperial bolt with a higher tensile strength.
or make an exception, and make your selt belt bolts metric (M12) to make it easier
James
posted on 24/1/09 at 12:55 AM Reply With Quote
Originally posted by gy351100
Hi all
Would it be a silly question to ask why you build the car this way? Is standard metric really so bad?
James
