flak monkey
posted on 24/1/09 at 01:35 PM |
MS progress...
A pictoral update of the progress on the MS conversion. Pretty pleased with how its gone to be honest. Had an annoying fuel leak, but it was locitite
to the rescue which seems to have cured that...
Just got back from a drive and datalog session. Slowly improving . One question for others using megalog viewer, should I have acceleration
enrichments on or off? I have got the AFR target tables turned on, so thats working quite well already, just unsure about the acceleration enrichments
bit..
Anyway heres the pics:
Sera
http://www.motosera.com
| posted on 24/1/09 at 01:50 PM |
Looking very tidy!!
Did you drill your fuel rail with the special cutting bit of just an approximate size drill?? I'm trying to decide whether to go down the 15mm
copper pipe route as my machine capabilities are limited......
flak monkey
| posted on 24/1/09 at 01:58 PM |
Rail was drilled will the correct sized drill with lots of white sprit as cutting fluid. Works well and doesnt seem to leak. In my case the hole was
10.8mm.
Ended up drilling and tapping the ends to 3/8" BSPT as hose tails were readily available.
Sera
turboben
| posted on 24/1/09 at 02:02 PM |
I think you can leave the enrichments on and the log viewer calculates around it. I leave it on anyway.
Ben
omega 24 v6
| posted on 24/1/09 at 04:15 PM |
I left mines off but can't remeber why. I'm sure I asked on msefi and got an answer to leave them off. But as with all things megasquirt
you get differing answers all round.
turboben
| posted on 24/1/09 at 04:53 PM |
http://www.ideasandsolutions.biz/MegaLogViewer/veAnalysis.html
Hope that link works - its should be the destructions.
mark chandler
| posted on 24/1/09 at 05:18 PM |
All enrichments off when logging, just us the controls gently.
You will know how good you map is when you have finished, in utopia you would not need enrichments, so the less the better!
For myself I need a little acceleration and no ego correction now I am done and dusted.
Regards Mark
mark chandler
Regards Mark
flak monkey
| posted on 24/1/09 at 05:41 PM |
Now done 5 successful runs and logs and its getting there quite well, and is already better than on carbs with regards AFR. Still a few very rich
spots at the moment though.
Currently AFR targets are on all other enrichments are off.
Need to do some longer drives with the logger running so looking in to sourcing an inverter to run the laptop off
Sera
omega 24 v6
| posted on 24/1/09 at 07:09 PM |
Well done David. Now I gotta get me through sva and do some real datalogging on real roads. Airfield was fine to get it going but hardly an ideal
scenario for dattalogging
mark chandler
| posted on 25/1/09 at 02:28 PM |
I,ve got a scruffy old thinkpad I use, it's quite happy running straight of the cars battery.
Spent hours setting mine up, I used autotune which contary to lots of other posts works well, you just need to play around with the settings, start
off with a wide window and as the tune improves close this down.
Regards Mark
| posted on 25/1/09 at 07:42 PM |
I bought
one of these rather
than using an inverter. It works fine for me, but check your laptops current requirements.
paulf
| posted on 25/1/09 at 09:11 PM |
I data log using a palm PDA and palm log, then download it to a laptop to adjust with megalog viewer.Laptops are not a good idea in the car as the
hard drives is not really designed to be bounced around in a car at speed.
The palm can also be fitted to the dash and used to adjust basic settings and display realtime data.
Paul
flak monkey
| posted on 26/1/09 at 08:40 AM |
Paul
Not a bad idea that, I dont, however, have a suitable cable for connecting to my PDA.
Thats assuming palmlog works on win mobile....
Otherwise it looks like the laptops going to get a battering.
Sera
