posted on 27/1/09 at 10:43 AM |
All Alloy Pinto engine
Not sure if this has been posted before...
Just been reading the latest Burton Power catalogue and noticed that they now offer an alloy Pinto (SOHC) cylinder head. They have offered alloy
Pinto/Cosworth engine blocks for some time, but with the new cylinder head you could, potentially, build an all alloy Pinto.
OK you get a bare weight saving of around 40kg over the standard cast iron items and if you're building a classic Ford and want to maintain the
Pinto engine fitment or possibly competing in particular race series, but.....
....it's going to cost you a sh1t load of cash to do. Like £4k for the block and £3k for the head + crank, rods, pistons, cam, flywheel, bolts
etc - let's say easily £10k+.
It seems a crazy proposition to me, but I'd love to see someone go the whole hog and fit an all alloy Pinto fully tuned and mated to a Quaife
sequential gearbox.
Alloy Pinto/Cosworth block
Alloy Pinto cylinder head (2nd from top)
Mr Whippy
posted on 27/1/09 at 10:54 AM |
IMO thats just plain stupid, 10k for a pinto! when you could have a new v8 like this for less than half that ready to go and its already made of
aluminum too...
New 4.0 & 4.6, fully assembled 'turn-key' engine, Turnkey engines as shown come 100% complete & ready to run. Starter, wiring,
alternator, Serpentine endless pulley belt system, fuel injection, clutch, flywheel, rocker covers, breathers, fillers, timing cover etc. etc.
Complete engine £4,895.00
posted on 27/1/09 at 11:00 AM |
My thoughts exactly as you can get a brand new Duratec with 200+bhp ready to go for around £6-7k.
I'd still like to see someone do the alloy Pinto thing though, just because it can be done
Mr Whippy
posted on 27/1/09 at 11:03 AM |
even the duratec sounds over priced tbh I'd rather have the sound and the torque of a v8 anyday
bimbleuk
posted on 27/1/09 at 11:09 AM |
I recently met a couple of guys at a dyno with their mint mk1 Escort strapped to the rollers. Complete ground up restoration to then compete in some
road rallying. Cost? a mere £90K!! to completion.
They wouldn't produce them if there wasn't the demand!
Mr Whippy
posted on 27/1/09 at 11:17 AM |
bet they weren't married
posted on 27/1/09 at 11:27 AM |
maybe to each other and/or the car...?
Mr Whippy
posted on 27/1/09 at 11:45 AM |
maybe to each other
well...I didn't want to say, but probably
posted on 27/1/09 at 11:53 AM |
Why? total waste of cash when BRAND NEW zetec's are only £700.
Then cams, throttle bodies & exhaust and 220bhp.
iank
posted on 27/1/09 at 12:01 PM |
I think the point of these is purely where some racing regs specify exactly what pinto cams, crank, piston, rods etc you are allowed to use, but
don't specify what the block/head have to be made from.
Maybe pub bragging rights are worth £7k these days, but I can't see that personally.
Anonymous
mr henderson
posted on 27/1/09 at 12:10 PM |
aluminum too...
In the interests of accuracy- you forgot to add the VAT, and you will need an ecu and an air mass meter!
mcerd1
posted on 27/1/09 at 12:14 PM |
have any of you ever seen the price of a warrior 16v engine (pinto based, 16v alloy head)
I think they were around the 16k mark for a complete 2.4 / 2.5 engine with a steel bottom end - and that's with an iron block
(I think its about the same for a new top spec 2.3 cossie duratec)
but I can't say too much as I'm building mine with a steel bottom end
I used mostly standard s/h cossie bits - but it still makes no financial sense at all
(but I will 'eventualy' have a 9000rpm rev limit on 1989 emissions )
[Edited on 27/1/09 by mcerd1]
posted on 27/1/09 at 12:19 PM |
that is awful news as it could be the end of the boat anchor jokes
Burton do, and have been doing for sometime, an alloy crossflow head.
posted on 27/1/09 at 12:30 PM |
...and an alloy block is also available too IIRC
Mr Whippy
posted on 27/1/09 at 12:50 PM |
thats still not going to get them a girlfriend
mcerd1
posted on 27/1/09 at 01:27 PM |
not quite, you've still got the old ford V6's
idl1975
posted on 27/1/09 at 01:54 PM |
Or just buy a decent Chevy V8 from almost any US scrapyard and have it shipped to you for under a grand...conservatively fuelled, it will probably use
less petrol, too.
aluminum too...
mangogrooveworkshop
posted on 27/1/09 at 04:45 PM |
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&ssPageName=STRK:MEWAX:IT&item=370148189290#ebayphotohosting
[Edited on 27-1-09 by mangogrooveworkshop]
Example engine specification: Ford 2.0 litre Pinto, 2046cc, (bore 92mm), crankshaft: 76.95mm billet steel, forged steel conrods, forged alloy pistons,
steel flywheel, dry sump (2 Gal), WARRIOR 16 Valve Twin-Cam Cylinder Head, 2 x 48mm Weber DCOE carburettors, DA 10 cams, Power 238 bhp at 7500 rpm,
Torque 185 lbs.ft at 5500 rpm. With more radical cams and 50mm Weber DCOE carburettors 270 bhp at 8000 rpm and 205 lbs.ft at 5500 rpm can be
achieved.
The WARRIOR Cylinder Head has proved both extremely popular and effective in Eire with competitors in the closed road tarmac rally championships.
WARRIOR equipped engines are also successful in rallying and hillclimbing all over Britain, Europe and even Australia.In 2005 Connaught built a very
special 2400cc engine which produced over 300 bhp and 230 lbs.ft of torque on full engine management. Connaught will be pleased to quote for your
particular requirements please remortgage your house and sell your children before placeing the order
