Author: Subject: What do we think about these throttle bodies?
adrianreeve
posted on 30/1/09 at 12:02 PM Reply With Quote
Hi there, followed Big Wasa's advice and bought some bodies off ebay for £35. Got excited, because the description was for CB900 throtle bodies, but the piccy was GXSR600 TBs.
When they arrived, they are the CB900 Hornet ones. From a quick bit of research, the GSXR ones have 38mm bore, and the CB900 ones have 36mm bore.
My question is, are the CB900 ones going to be ok? I was thinking that Weber 40's ususally have a 34 / 36mm choke, so these should be at least as good?
Could someone just put my mind at rest!!
Adrian
posted on 30/1/09 at 12:09 PM Reply With Quote
Just depends what engine your running. I got some off the bay this week and measurign them they are a whopping 55mm
adrianreeve
posted on 30/1/09 at 12:12 PM Reply With Quote
Sorry, being stupid! They are for a 2l Zetec Silvertop.
Adrian
posted on 30/1/09 at 12:29 PM Reply With Quote
They will flow better than a DCOE40 even with the maximum choke size fitted so I wouldn't worry about it.
grazzledazzle
posted on 30/1/09 at 01:28 PM Reply With Quote
Are you aware you might have some real problems with these? Might be worth selling on and getting hold of something circa 42mm which is ideal.
mark chandler
posted on 30/1/09 at 01:31 PM Reply With Quote
The bike would run around 150-160bhp with margin to improve on this, should be good to around 200bhp I would have thought.
Because they are a little smaller you will get a better MAP signal drivability improved in the mid range etc. How often are you at 7000rpm foot hard down?
Also no secondary butterflies to rip out and can be spilt into two pairs.
"ideal" springs to mind.
stevebubs
posted on 30/1/09 at 01:42 PM Reply With Quote
They sound fine for a standard engine.
cd.thomson
posted on 30/1/09 at 02:12 PM Reply With Quote
Haha, yes he knows, theres no telling him though!
Craig
posted on 30/1/09 at 03:10 PM Reply With Quote
55mm per body! Holy moly!! That's seriously big. That's the recommended throttle body size for 160Bhp for a SINGLE THROTTLE BODY!!!!!!!
posted on 30/1/09 at 04:29 PM Reply With Quote
So, four of them mounted straight against the head... VROOOOOOMMMMM!!!!!
I do have a 43mm set as well as the 55mm ones are single and I need 4 then mounting them together etc...
adrianreeve
posted on 30/1/09 at 04:59 PM Reply With Quote
Thanks for the replies chaps - looks like I have got myself a good set then!
grazzledazzle
posted on 30/1/09 at 05:16 PM Reply With Quote
Or cough splutter stall...bastard won't start?
