Author: Subject: using donor fuel line
hughpinder
posted on 6/2/09 at 11:09 AM Reply With Quote
I was planning on using the fuel line from my donor mundano, which is 6.4 mm bore, 8.2 od(this should allow enought fuel flow for 300 bhp at 3 bar, so I guess its more than big enough!). The question is, is mr IVA going to like it, as it has absolutly no markings on it to say its ok for fuel use!
Anyone know?
Hugh
tomprescott
posted on 6/2/09 at 11:13 AM Reply With Quote
I think it needs markings, I remember somebody else saying that theres failed because it didn't have the appropriate markings.
Mr Whippy
bad boy!
how much is fuel line? how much would you car cost to replace if it went up in flames?!
buy new hose...god I though I was a cheap skate
Pdlewis
posted on 6/2/09 at 11:14 AM Reply With Quote
Surely for the pric of fuel line youd be better with new. Copper microbore is £5 from your local plumber and rubber hose isnt much more then you know its all new
Build Photo Album
Updated 05/02/2009
pewe
posted on 6/2/09 at 12:11 PM Reply With Quote
Wot they said ^^ but make sure "rubber" pipe is marked for fuel use and any clips are fuel pipe clips (i.e. not jubilee).
Cheers, Pewe
hughpinder
posted on 6/2/09 at 12:48 PM Reply With Quote
Thanks for the replies - I suppose I should have said its the metal fuel line I'm looking at, not the rubber and clips (which I will be buying new), and it's in perfect condition, otherwise I wouldn't consider using it (but I'm glad to see you're all concerned for my safety!)
Does the IVA/SVA allow copper microbore - surely thats not correctly marked either?
Thanks again
Hugh
AdamR
posted on 6/2/09 at 01:36 PM Reply With Quote
Only the rubber stuff needs to be marked, so copper microbore or any other metal pipe is fine. That's my understanding anyhoo...
