adrianreeve
| posted on 7/2/09 at 01:38 PM |
Where to buy fuel rail?
Does anyone know a good source of fuel rail blank - I need to make a new one for my re-spaced bike bodies.
Alternatively, if anyone can make one to order, I may be interested.
Adrian
[Edited on 7/2/09 by adrianreeve]
clairetoo
| posted on 7/2/09 at 01:47 PM |
I got mine from these guys - even with postage from the states it was still a load cheaper then
buying it here
Its cuz I is blond , innit
Claire xx
Will weld for food......
flak monkey
| posted on 7/2/09 at 02:15 PM |
Same as Claire, I bought it from rossmachine racing.
They sell on ebay too. Think it worked out about £40 or £50 when I got mine.
Sera
http://www.motosera.com
liam.mccaffrey
| posted on 7/2/09 at 02:49 PM |
ditto ross machine
Werner Van Loock
| posted on 7/2/09 at 03:41 PM |
Still quite expensive, anyone know if this would work?
http://cgi.ebay.co.uk/ford-mondeo-mk2-2litre-zetec-fuel-injector-rail_W0QQitemZ230323053049QQ
or this
http://cgi.ebay.co.uk/Ford-Focus-57-MK3-1-8-Zetec-injectors-fuel-rail_W0QQitemZ260354269665QQ
They're from a zetec, so spacing should be correct, it are top feed injectors, that should also be ok, only thing i can think of is that it
would foul somewhere on respaced gsxr throttle bodies
I know these won't work because it are side feed injectors:
http://cgi.ebay.co.uk/ford-mondeo-fuel-rail-dohc-zetec-si-lx-glx-ghia-escort_W0QQitemZ110345636214QQ
http://www.clubstylus.be
martyn_16v
| posted on 7/2/09 at 06:10 PM |
Another for Ross Machine. They charged less postage to send it across the atlantic than the UK distributor wanted, and the rail itself was half the
price...
MikeR
| posted on 7/2/09 at 08:28 PM |
How do you figured out where to drill the fuel rail?
This is something i've never quite understood and hence found the idea of using copper pipe attractive.
flak monkey
| posted on 7/2/09 at 08:50 PM |
Not tricky, just measure the spacing of the throttle bodies and drill the rail to suit the injectors.
Sera
stevebubs
| posted on 7/2/09 at 09:01 PM |
I respaced mine to standard jenvey / DCOE spacing.
I then just used an off the shelf jenvey item...
martyn_16v
| posted on 8/2/09 at 02:46 PM |
The same way as you'd work it out using copper surely. No matter what you use, at some point you'd need to measure the distance between
injectors?
MikeR
| posted on 8/2/09 at 03:02 PM |
Aha - but with copper heating pipe you've got a little bit of leeway.
They fit into the 15mm T peices. So fit those and you then measure copper to fit between. If youre a couple of mill out it doesn't matter as
you've got about 10mm either side of the T to play with and still get a good joint.
With the proper fuel rail I was thinking more than 1 or 2mm out and you'd be stuffed, hence the worry.
