Poll: Do I need a high pressure filter [View Results]
Yes
No
Author: Subject: Do I need a high pressure filter
Snuggs
posted on 12/2/09 at 05:16 PM Reply With Quote
Do I need a high pressure filter between the high pressure pump and the injectors ?
http://www.topcashback.co.uk/ref/snuggstcb
Spider pig, spider pig, does whatever a spider pig does.
I doubt therefore I may be.
Luposlipophobia : Fear of being chased by wolves around a freshly waxed kitchen floor, while wearing only socks on your feet.
My mind not only wanders, sometimes it leaves completely!
http://www.venganza.org
http://www.jesusandmo.net/
http://www.snuggs.co.uk
clairetoo
posted on 12/2/09 at 05:24 PM Reply With Quote
Yes !
Its cuz I is blond , innit
Claire xx
Will weld for food......
speedyxjs
posted on 12/2/09 at 05:25 PM Reply With Quote
Yep
philw
posted on 12/2/09 at 05:29 PM Reply With Quote
I haven't got one, mine is filtered before the pump.
Must try harder
clairetoo
posted on 12/2/09 at 05:37 PM Reply With Quote
So..........anything coming adrift in the pump goes straight to the injector's ?
Claire xx
philw
posted on 12/2/09 at 05:51 PM Reply With Quote
Hmmm good point, i did look for a filter to go in between but ended up with a Sytec pre-pump filter, i have to change the pipe work and pump position so what should i do?
Must try harder
Phil.J
posted on 12/2/09 at 06:00 PM Reply With Quote
Definitely, and a pre-filter too if you value the pump.
clairetoo
Just fit a generic high pressure/injection filter after the pump - mine is from Halfraud's (for a BMW , I think) - cost about a fiver
I mounted mine with an old coil bracket .
Claire xx
Snuggs
posted on 12/2/09 at 06:47 PM Reply With Quote
Will this one be OK ?
http://cgi.ebay.co.uk/CITROEN-PEUGEOT-RENAULT-SMART-FIAT-VAUXHALL-FUEL-FILTER_W0QQitemZ310090781203QQcmdZViewItemQQptZUK_CarsParts_Vehicles_CarParts_S M?hash=item310090781203&_trksid=p3286.c0.m14&_trkparms=66%3A2|65%3A15|39%3A1|240%3A1318
posted on 12/2/09 at 06:57 PM Reply With Quote
Yes! Definately worth using. A post high pressure pump is cheap, new fuel injectors are not!!!
Not worth risking it IMHO!!
