A1
| posted on 14/2/09 at 03:03 PM |
03 r1 fuelling
i fitting the fuel lines soon, i need a return from the throttle body to the tank? also, i got the new tank from mk, and it has an extra nipple on top
next to the tank breather one... any ideas what its for?
cheers
fesycresy
| posted on 14/2/09 at 04:10 PM |
Yep a return is needed.
I would guess the nipple is for the return !
Don't forget you will need a pressure regulator, otherwise the fuel will not have sufficient pressure at the throttle bodies and it'll
take the easiest route back to the tank.
afj
| posted on 14/2/09 at 05:41 PM |
the fuel feed and return are in the pump at the bottom of the tank if your using the bike fuel pump, then you use the 2 top 'nipples' for
the breather
eerrrrrrrrrrrrrrrr
