omega0684
| posted on 16/2/09 at 01:21 PM |
MS Help
i have been trying to get the car running this morning but its being a right b***h, its not firing! i've had the plugs out and they are black as
the ace of spades, so the car is obviously running rich, and i have plenty of sparks so why isn't it firing? is it possible that there is too
much fuel going in and flooding it? i have read through the manual and it says that it could possibly be the cranking pulse width, which is about
14ms.
any ideas?
vinny1275
| posted on 16/2/09 at 01:29 PM |
Hiya,
Mine started first time, but I think that was maybe more luck than judgement!
First off, don't forget the enrichment bits in there - they'll add to the fuel going in. If they're set to enich as it's jsut
started or warming up, they'll be skewing the VE.
Then look a the VE table - I used the calculator for the pulse widths, can't remember off the top of my head what it came out with - 14 sounds
about right tho. Just by fiddling about, I managed to lean the fuel off by a $h1tload to get a nice idle - I think I got it down to about 25% (the
table started off at 100% I think), so lean it off.
I take it you've read the megatune manual? It's really handy for getting the right bits in the right order..
You could haev my map, but I've only played with it for about 10 minutes so far! From your other question, I've got a 285 cam, big valves
and GSXR TBs on a 2 litre Pinto, and cranking I'm on about 14 degrees advance, and going up as it moves up the rev range, but 10 deg should be
good enough to at least get it started.
Finally, are you sure you're getting the sparks at the right time, haven't got the leads swapped or anything like that?
vince
omega0684
| posted on 16/2/09 at 02:26 PM |
vince u have u2u
flak monkey
| posted on 16/2/09 at 02:31 PM |
I will post my base fuel map up later. Got me running straight away. But you will need to add your spark info back in as its fuel only.
Does it start then run for a few secs? If so its not the cranking PW it will be the after start enrichments. If it runs for more than 20secs or so
then dies it will be your VE table.
You should be looking at around 12 deg at idle for yourset up too Alex. I also assume you are running Alpha-N? If so make sure you have calibrated
your TPS and the values in the spark and fuel tables relate to that.
Sera
http://www.motosera.com
flak monkey
| posted on 16/2/09 at 05:07 PM |
Like I said, its well rich, but should get you up and running with the addition of some spark info.
Sera
omega 24 v6
| posted on 16/2/09 at 05:52 PM |
Post up some more info Omega.
i.e.
edis or wasted spark on board ign drivers.
post your msq as well
As already said try swapping over the 2 coil wires ( if it's wasted spark) and see if it fires you could be 180 degrees out on the spark
timing.
