omega0684
| posted on 11/3/09 at 04:12 PM |
Autotune
how does autotune work in MS? is a chase of turning it on and going for a drive and the MS with tune the car as you drive?
paulf
| posted on 11/3/09 at 08:35 PM |
Yes I tried auto tune and found it not to be of much use.It is set up to only work over a small band of loads etc and needs the INI file in megatune
editing to work over a usefull range.I used megalog viewer with a narrow band and found it works quite well even with just a narrow band if you also
manuallly confirm the resulting figures.
Paul
Jenko
| posted on 12/3/09 at 06:51 PM |
Yep agree with Rob.....The idea is great but in reality, it's soo much better to get a good base map and not rely on the auto tune....
I found the base afr map was not suited to my engine......Great if you know exactly where you want a given AFR, but mapping with a wide band is much
better.
PJ.
MY BLOG - http://westfieldv8.blogspot.co.uk/
flak monkey
| posted on 12/3/09 at 07:37 PM |
Another vote for megatune here. Works very well indeed, probably done 15 runs with mine now and its getting very close....
Sera
http://www.motosera.com
