phoenix70
| posted on 13/3/09 at 12:45 PM |
Fuel Pressure Regulator
I'm just going to fit my new adjustable pressure regulator I bought off Ebay, but I can't figure out which port in the input and which
is the output. Is there anyway to tell, as there is not instruction with it, and there is no marking on the FPR itself
There is a port on the side of the unit, and one on the bottom
Cheers.
Scott
matt_claydon
| posted on 13/3/09 at 12:52 PM |
Carbs or injection? Any chance of a photo?
omega0684
| posted on 13/3/09 at 12:58 PM |
if its a fuel injection one with a gauge, the inlet is the one going in the back and the outlet is the one coming out of the bottom, you should also
have a small vacuum outlet on the side as well
phoenix70
Fuel Injections
Here is a piccy of it
  FPR
omega0684
| posted on 13/3/09 at 01:07 PM |
yup inlet at the back, outlet on the bottom, vacuum on the right
mine came with a little bit of paper with at diagram on it, did you not get one with yours?
[Edited on 13/3/09 by omega0684]
| posted on 13/3/09 at 01:34 PM |
As described. Mine came with a nice little diagram too!!!
JAG
| posted on 13/3/09 at 01:48 PM |
Errrr where would a chap buy one of those?
Justin
phoenix70
| posted on 13/3/09 at 02:20 PM |
if you feel brave Ebay, thats where I got mine (minus a diagram by the sound of it)
P.S. Does anyone know what the plates with the barbed connectors on it are for, I've got no idea.
omega0684
| posted on 13/3/09 at 02:34 PM |
here you go justin you can even pick them in different colours
ebay
link
rpm
| posted on 13/3/09 at 03:06 PM |
i;ve been loking at these as i need one myself, are they any good? ie do they hold a good steady pressure?
oh also how big is the unit? as i seem to have run out of room under the bonnet!
[Edited on 13/3/09 by rpm]
v8kid
| posted on 13/3/09 at 04:05 PM |
Looks just like the one I bought off ebay.
Pressure drops right off when under load on the rolling road.
Mapping compensated for it but if my injectors had not been oversizes i would have been in the poo.
rpm
| posted on 13/3/09 at 05:37 PM |
thats what i was a bit wary of, thanks for the heads up.
cheers Roger
