Snuggs
| posted on 21/3/09 at 11:06 AM |
Fuel line bleed valve
Do you need to fit a bleed valve in the fuel line/fuel rail ?
Clive
http://www.topcashback.co.uk/ref/snuggstcb
Spider pig, spider pig, does whatever a spider pig does.
I doubt therefore I may be.
Luposlipophobia : Fear of being chased by wolves around a freshly waxed kitchen floor, while wearing only socks on your feet.
My mind not only wanders, sometimes it leaves completely!
http://www.venganza.org
http://www.jesusandmo.net/
http://www.snuggs.co.uk
clairetoo
| posted on 21/3/09 at 11:16 AM |
Cant think of a reason to - I never have (since any air is cleared back to the tank in the return line )
Its cuz I is blond , innit
Claire xx
Will weld for food......
Snuggs
| posted on 21/3/09 at 11:37 AM |
Cheers Claire,
I am using a modified Vauxhall Omega V6 fuel rail and it has one fitted !
Just wanted to check with the gurus on here b4 I removed it
Clive
clairetoo
| posted on 21/3/09 at 11:51 AM |
It's probably for putting a pressure gauge on , to check fuel pressure when dealer serviced ?
Claire xx
| posted on 21/3/09 at 12:26 PM |
It may be to release pressure for maintenance procedures as well.
| posted on 21/3/09 at 01:36 PM |
Sounds like your close to getting it running Clive? What have you done for your inlet manifold?
Snuggs
| posted on 21/3/09 at 07:54 PM |
Got the RPI Boxer manifold I was after.Going to fit 4 x 48mm throttle bodies and 8 injectors.
Hope it all works when I finally get it all assembled
