bassett
posted on 26/3/09 at 10:46 PM |
Faulty fuel pump - anything i can do?
Hi, my mnr supplied bosch 070 fuel pump failed the other day. i was wondering if anyone knows if theres a guarantee on items like these or not. It
certainly wasnt electrical fault as no fuse went on the r1 wiring. only thing was it did run out of fuel but this doesnt happen on the tin top does it
so is it fit for purpose?
cheers
Adam
mark chandler
posted on 26/3/09 at 11:30 PM |
EFI pumps will not last long without fuel, they overheat and fail very quickly as the petrol cools them.
If your pump is wired correctly into the injection it should stop when the engine is not running, limiting damage, if you have wired up seperately
allowing it to run full time then I suspect its an own goal.
You do not need to buy this specific pump, any EFI pump that can achieve 4-5 bar pressure will do, I run my blade engine on one of
these
It can fuel a 4 litre jag @ £25 posted, mine came next day, you cannot go wrong, the regulator just spills more fuel back to the return.
Regards Mark
omega0684
posted on 26/3/09 at 11:48 PM |
i used the same pump as well, bomb proof!
bassett
posted on 27/3/09 at 01:05 PM |
It was wired as in the bike - pump wires extended. The engine ran on fuel in the system till it cut out and pump cuts at the same time as the engine.
After that brief period it ran of fuel in the pipes with no fuel in the tank and pump was a goner, literally seconds.
Dusty
posted on 27/3/09 at 02:22 PM |
Did you have a filter in the feed to the pump. They don't like dust/grit/sand or other debris.
