omega 24 v6
| posted on 30/3/09 at 04:31 PM |
Megasquirt audit warnings
WARNING(04): Constant "afrBins1" units mismatch, "Volts" in msq, expected "AFR" from ini.
WARNING(04): Constant "afrBins2" units mismatch, "Volts" in msq, expected "AFR" from ini.
Above are 2 lines from my audit log. They were never there before when i was setting the unit up a while back. All i have done since then was to
analize and save it in megalog viewer.
My set up is v2.2 msns extra code 029y3 with itbs ( suzuki gsxr 1000 ITBS) wasted spark and lc1 wideband with controller. Vauxhall redtop 2ltr xe
engine.
As it's been a while since I looked at it/read up on it I was hoping for a quick answer from the informed members of this forum.
Obviously one of the settings is wrong but which one? the ini file or the msq.
omega 24 v6
| posted on 31/3/09 at 08:11 PM |
Found it.
After trawling through the code (msq) in notepad I found that for some reason the nitrous afr table units were in volts instead of afr. Ah well seeing
as i've not got nitrous it'll not be a problem.
