Krismc
| posted on 8/4/09 at 06:56 PM |
How do i fit a back plate for a filter?
How do i fit a universal backplate to my throttle boddies for a Pipercross filter??
I dont have anywhere to attach it on the gsxr K5 750 throttle boddies!!
any ideas? and if i cut the holes to the exact size(out side diameter of 54mm) how do i stop them drawing in air??
clairetoo
| posted on 8/4/09 at 07:25 PM |
What I do is...................knock up a set of carbon trumpets , and a carbon backplate .
The cut the the holes in the backplate to fit a little way up the trumpets , and then bond the backplate to the trumpets..........simples
Its cuz I is blond , innit
Claire xx
Will weld for food......
Krismc
| posted on 8/4/09 at 08:23 PM |
No rubbers and SVA is next week!!
Been in the garage since ive posted and decided that im going to cut the Holes to 54mm, which i think is the outside diameter of the throttle
boddies(cant tell properly ive lost my calipers)
Then fit it over, use 2 small brackets to hold plate in position, then use some silicon tube and jubilee clips(one on each hole) put them on after the
plate.
Jobs a gud un
