Author: Subject: Fuel hose clips
Snuggs
posted on 9/4/09 at 11:12 AM Reply With Quote
Fuel hose clips
NTDWM
Found these http://trueasset.org.uk/index.php?page=hose-clips
Same as the manufacturers use.
A lot better than screw type hose clips.
http://www.topcashback.co.uk/ref/snuggstcb
Spider pig, spider pig, does whatever a spider pig does.
I doubt therefore I may be.
Luposlipophobia : Fear of being chased by wolves around a freshly waxed kitchen floor, while wearing only socks on your feet.
My mind not only wanders, sometimes it leaves completely!
http://www.venganza.org
http://www.jesusandmo.net/
http://www.snuggs.co.uk
posted on 9/4/09 at 11:38 AM Reply With Quote
Are you sure???
Whenever I've had weeping hose joints it's been cos of those things. You can't just screw 'em even tighter like with a jubilee clip.....
Perhaps they fail because I re-use them and they lose their springiness....
damajin
posted on 9/4/09 at 11:47 AM Reply With Quote
I don't think I'd want to trust my fuel lines to be held in place with a spring clip. The one thing you don't want to be leaking all over a hot engine and your wiring is petrol!!!
D
posted on 9/4/09 at 11:50 AM Reply With Quote
When dealing with any small hose to get a true seal you have to get exactly the right size --- both types of clip have advantages and disadvantages.
Mr Whippy
posted on 9/4/09 at 12:02 PM Reply With Quote
Those were designed by the devil, personally I loathe them
Danozeman
posted on 9/4/09 at 12:36 PM Reply With Quote
Most mechanics i know, me included sling them in the bin and put jubilee clips on.
If you have a slight weep which u will after theyv been off and refitted u cant just nip them up.
Dan
omega0684
posted on 9/4/09 at 01:47 PM Reply With Quote
THEY ARE NOT FUEL CLIPS!
they are normally used by manufacturers for securing water pipes on the radiator and expansion tank, they are crap and should be replaced on every vehicle in my opinion, i have replaced them all on my tintop with jubalee clips and haven't used them at all on the kit car.
this is a fuel clip
posted on 9/4/09 at 03:53 PM Reply With Quote
The clips that Omega 0684 shows are great for fuel lines DO NOT use Jubilee clips as they cause small hoses to bunch up and leak , the fuel hose clips exert even pressure around the hose . As for the type shown by Clive (snuggs) they are used by some manufacturers on fuel lines , the old injected Fiesta's used them
