chris-p-duck
| posted on 17/5/09 at 10:39 AM |
low pressure pump mounting
Hi all,
I am in the process of mounting my low pressure fuel pump and am in a quandry about the fixings. I have one of these -
http://www.rallydesign.co.uk/product_info.php?products_id=13662
but have some space issues and was looking to only use one of the mounting lugs. So my question is - if I only use one of the fixings am I going to
get issues with it vibrating itself free over a period of time? and if so what can I do about it (apart from using both lugs!)
Chris
| posted on 17/5/09 at 11:04 AM |
I think the main reason for putting these pumps onto rubber bobbins is noise - they do clatter a bit, and if they're mounted directly onto the
chassis then the noise will be transmitted through the car.
I have a bike pump on rubber mounts, and it's clearly audible when I turn on the ignition.
mark chandler
| posted on 17/5/09 at 11:43 AM |
Mine bolts straight to the floor, it does clunk a bit.
Ideally you want it low why not put it in the back by the tank, must be loads of space there.
Regards Mark
chris-p-duck
| posted on 17/5/09 at 11:49 AM |
I was planning on mounting it right in front of the tank and solidly to the chassis. However my chassis is not a normal spaceframe chassis and I only
have a small space to put it in, It has to share that space with the swirl pot, filter and high pressure pump as well!!
I had thought of using one one of the fixings and putting the other lug though a slot in the panel.
Chris
omega0684
| posted on 17/5/09 at 12:00 PM |
when i ran that fuel pump om my carbs i mounted it on the chassis rail behind the drivers seat on two strips of rubber, very quiet, and no vibration.
