goaty
posted on 20/5/09 at 09:17 PM |
Atlas diff
Hey all,
Just got myself a capri lsd with shafts for my atlas axle.
I want to get it serviced and i think you can get it to motorsport spec too, but can anyone recomend someone to use??
Also, when its fitted it will need setting up right??? do they need it in the axle to do this??
sorry for all the questions, just want to make sure its doen the right way.
cheers
goaty
blakep82
posted on 20/5/09 at 09:19 PM |
yeah they'll need th axle too.
how much did you get the LSD for if you don't mind?
________________________
goaty
posted on 21/5/09 at 06:25 AM |
no i dont mind. It was a complete axle but getting the tube sent would cost a bit plus i am going tuse the one already fit in my car. Diff, pinion and
shafts for £350...so not too bad really.
HOL
posted on 21/5/09 at 07:19 AM |
Just make sure the one in the car is a proper Atlas and not a Cortina Koln before you ditch the new case. The 2.8 diff wont fit in a Koln.
The dif ratio on the 2.8 is about 3.09, so you might want to consider a CWP change, if you have not planned that already.
BearingKits
posted on 21/5/09 at 08:17 AM |
Speak to John at Fostek Engineering.
http://www.fostek.co.uk/about.html
www.Bearingkits.co.uk
Gearbox, Differential and Axle rebuild parts.
goaty
posted on 21/5/09 at 09:47 PM |
only downside to fostek is they are a long way away form me. Gartrac isn't far. I have emailed them asking what the costs would be to sort it
and set it up. Hopefully it wont be too bad.
prawnabie
posted on 21/5/09 at 10:18 PM |
Im pretty sure blake has spent upwards of a grand getting his atlas to spec.
