JAMSTER
| posted on 16/6/09 at 07:01 PM |
megasquirt
anyone know of somewhere/someone to set my megasquirt in peterborough area i\'m getting very pissed off with it hope you can help
flak monkey
| posted on 16/6/09 at 07:08 PM |
Whats up with it?
What engine and set up do you have?
Sera
http://www.motosera.com
JAMSTER
| posted on 16/6/09 at 07:20 PM |
2.0 zetec fz2001 cams gsxr 600 tbs megasquirt 2.5 with edis
madteg
| posted on 16/6/09 at 07:23 PM |
Does it run at all.
clairetoo
| posted on 16/6/09 at 07:27 PM |
It would help if you put something in your location - you never know , you might live just down the road from someone who could help
Its cuz I is blond , innit
Claire xx
Will weld for food......
JAMSTER
| posted on 16/6/09 at 07:28 PM |
yes runs / drives but not to far also has inovate lc1 o2 sensor i fix cars all day long just don't know about mapping constants etc etc i feel i
should have stuck with my crossflow point's/ dizzy and carbs lol.
clairetoo
| posted on 16/6/09 at 08:13 PM |
Best to start with the basic's - what's your fuel pressure set at (should be about 45 psi)
How's your ignition timing ?
What have you set injector events to ? (2 squirts , alternating is a good start)
Req. fuel - start around 8.2 , and adjust fueling on the live tuning screen .
Claire xx
paulf
| posted on 16/6/09 at 08:29 PM |
Do you mean megasquirt 2.2 with Edis? if so its very similiar to my set up apart from the cams.Ive just swapped mine to Alpha -N set up from the speed
density i was using before and am in the process of remapping it.It is running quite well so far , if you want to look at my MAP then i can email it
to you when im next using the laptop.
Paul.
JAMSTER
| posted on 26/6/09 at 12:34 PM |
megasquirt
yes paul f if you could do that i would be a help
thanks
jamie
paulf
| posted on 26/6/09 at 09:05 PM |
Hopefully it is attached here,
JAMSTER
| posted on 27/6/09 at 06:29 PM |
thanks for that how are you getting on tuning yours using alpha n
paulf
| posted on 28/6/09 at 07:01 PM |
Ive got it running quite well apart from the common fault of having a snatchy throttle at low speeds due to the throttle sensor not moving enough to
altyer the map at light throttle openings, it is the opposite of the problems I had with speed density.
I also have a speed density map if that is what your using but think you would be better with Alpha n as you have uprated cams.
Paul.
JAMSTER
| posted on 6/7/09 at 08:43 PM |
