RMarine
posted on 2/7/09 at 06:28 PM |
whats a EDIS-module?
r1_pete
posted on 2/7/09 at 06:35 PM |
Fords Electronic Distributorless Ignition System.
The edis module is the bit which takes a signal from a trigger, usually a series of teeth or holes on a wheel, with one missing, a sensor detects the
missing tooth or hole, and depending on type fires the appropriate coil at the required interval, then using two signals PIP & SAW, the timing can
be varied by the ecu, megajolt or similar depending on engine requirements.
Paul (Notts)
posted on 2/7/09 at 06:37 PM |
It replaces the dizzy.
it needs an ecu such as megajolt to control it.
it tells the colipacks when to spark.
big_wasa
posted on 2/7/09 at 08:17 PM |
looks like this
[img][/img]
RMarine
posted on 2/7/09 at 10:48 PM |
Thanks all.
posted on 3/7/09 at 09:10 AM |
The whole EDIS system handles the complete task of crank/ignition synchronization as well as current sourcing for the wasted-spark coils. The task of
generating the desired ignition advance is performed by the ECU.
speedystew
posted on 6/7/09 at 05:30 PM |
sorry to hijack thread![](/images//smilies/bigsmile.gif)
so would i be right in thinking if you were using a weber alpha and carbs you would not need the edis as the crank sensor plugs straight into the
alpha
zetec novice![](/images//smilies/sad.gif) ![](/images//smilies/sad.gif) ![](/images//smilies/bigsmile.gif)
