jeffw
| posted on 11/7/09 at 05:35 PM |
Fuel Pressure
Just fitted a guage to my Jenvey/Zetec set-up to find I'm running almost 5Bar fuel pressure. I've turned this down to 3Bar...
What do we think it should be ?
flak monkey
| posted on 11/7/09 at 05:49 PM |
38 to 45psi is industry std
Sera
http://www.motosera.com
iscmatt
| posted on 11/7/09 at 06:10 PM |
= about 3 bar
| posted on 11/7/09 at 06:11 PM |
2.5bar (36 PSI) to 3 bar (44 PSI) is indeed pretty normal
5 bar is way too much!!
jeffw
| posted on 11/7/09 at 07:05 PM |
Cool....thanks
omega0684
| posted on 11/7/09 at 08:20 PM |
Bike throttle bodies run about 43-44 psi.
not sure about your jenvey's tho, shouldn't there be a recommended fuel pressure to complement the injector flow rate in the throttle
bodies!
paulf
| posted on 11/7/09 at 08:44 PM |
3 bar is normal , but now you have reduced it wont you need to re map the ECU? or else it may run lean you will at least need to correct the required
fuel figure.
Paul
jonesier1
| posted on 12/7/09 at 08:51 AM |
i was told to set mine to 3.5 bar by the boys at m-tec.thats a 2l zetec on gsxr t/b's
[Edited on 12/7/09 by jonesier1]
im in my own little world...its ok though they know me there
