prelude1980
| posted on 12/7/09 at 06:41 PM |
Megasquirt Logging
I've been on the megaquirt forum trying to find out if you can log wirelessly to a Windows Mobile phone but to no avail.
Anybody know if this can be done.
I have a bluetooth adapter for megasquirt but lacking the software for the phone
Speed has never killed anyone. Suddenly becoming stationary... that's what
gets you.
https://www.topcashback.co.uk/ref/dodd1980
omega0684
| posted on 12/7/09 at 06:57 PM |
why don't you just use a seriel-usb cable provided & connect to a laptop on the passenger seat?
prelude1980
| posted on 12/7/09 at 07:06 PM |
a few reasons really,
nearly lost my laptop a few time
The battery only lasts 30 mins if i'm lucky.
The screen closes with the wind.
dunno maybe i'm trying to be picky but i have a phone that could do the job and is easy to carry round just hoped i could use it
gets you.
BenTyreman
| posted on 12/7/09 at 07:18 PM |
Logging the raw data from the Megasquirt is very easy if you can write the software for your phone.
You transmit the character 'A' to the Megasquirt unit, and the Megasquirt returns the realtime variables (146 bytes worth for ms2extra
RC1).
Using the ini file (the top of the OutputChannels section), you can translate the raw data into meaning numbers later on a PC.
omega0684
| posted on 12/7/09 at 07:38 PM |
get a 240v power converter for the car (£15 from halfrauds),they plug into the cigarette lighter socket,
i wired in a perminant 12v feed to a cigarette lighter socket and the pluged the converter into it, that way you never loose power to the laptop,
then just plug the laptop in and your away, once the laptop is datalogging tuck it away in the footwell and the wind can't get to it or you
could take someone out with you to hold the laptop.
prelude1980
| posted on 12/7/09 at 07:56 PM |
RC1).
i did download a program called pocketdaq. but haven't managed to get it to talk to the ecu.
the 'A' does it need to be a capital letter?
gets you.
BenTyreman
| posted on 12/7/09 at 08:05 PM |
Yes.
I think 'a' was used for something on MS2 (something to do with CAN), but isn't any longer. Looking at the assembly code,
'a' DOES seem to do something, but I don't have enough knowledge of assembly to say what.
EDIT: it looks like 'a' could be used for transmitted the realtime variables from a second MS unit through the CAN bus. It probably
won't return anything just by sending 'a' as it's waiting for you to send the CAN ID.
[Edited on 12/7/09 by BenTyreman]
paulf
| posted on 12/7/09 at 09:20 PM |
Get a Palm pda from ebay for about £10 and install palm log on it. I do all my dataloging this way with it mounted on the dash so as it also acts as a
display of all the various parameters whilst driving.
Paul.
prelude1980
| posted on 12/7/09 at 09:22 PM |
does the palm need a cable and if so what sort?, can you import the logs into megalog viewer?
gets you.
| posted on 12/7/09 at 09:30 PM |
There is PocketTune, but development stopped on it several years ago so I don't know if
it will work with the latest MS firmware. Source is available though if you fancy improving it.
paulf
| posted on 12/7/09 at 10:03 PM |
Yes you need an older palm with a serial connection , you log to it then download in megalog viewer in burst mode , the log then can be opened as
normal using megalog viewer.Theres lots of info on the main megasquirt site about which models work best.
Paul.
